3.0 block heater location question.
Hello,
The wife ended up driving out the driveway without unpluging the block heater - wrecked the cord, and pulled it out of the truck... Replaced the end of the cord, but don`t know where the blug is ment to attach to the truck. Does anyone know where the female end is meant to plug into the truck for the block heater - any help is appreciated.
Thanks.
-I have tried searching, and found nothing pointing the direction.
Happy Holidays!
Thanks.
Happy Holidays!
They are indeed not a factory installed option, unless you have a diesel engine. They could potentially be anywhere, so there is no diagram to tell you where they are.
Thanks, I'll shall "check around the engine" that narrows it down a lot!
I am only asking as it's -40 degrees celcius here and i'm out in the cold and would like to spend as little time as possible searching.
I shall check round the oil filter - I realize it will probably be on the block. Just don't know where the frost plugs are in these engines. Never had one apart.
Happy New Years.
Happy New Years.
Happy New Years.
Happy New Years.
Would it help if I told you where it ISN'T installed?
the1998sr5
15
Jul 14, 2020 08:35 PM
BeMiceElf
Oct 10, 2015 09:40 PM
94 Newbie
Aug 6, 2015 10:33 AM
