22rte wont start
22rte wont start
any help im geting fuel to the cold start injecter and i have spark cant figure out what it can be timing has been checked. The engine was just rebuilt anyone know what it can be. there is a white double plug under the intake by the fire wall one plug goes to the transmission where does the other one go.
From: Cincinnati, Ohio - Amelia is the exact place. There is no one else on this site from where I am. Seems like everyone is from Cali or Washington. I guess I need to move.
If its isnt even turning over check
1. starter is actually in the hole, i had mine fall out on the way home from work last week, and wire brush the contacts and terminal
2. check fuses takes about 4 minutes to check all of them
3. make sure all of your grounds are hooked up (valve cover, chasis to engine coming of starter wire)
If it is rotating but not catching check
1. if it cranks all slow or backfires out of the air box, turn your dist around
2. pull the 19mm bolt going to the fuel rail, you will need a new crush washer, and see if you have a steady stream of fuel with the key turned to acc. dont try to start but see if you have constant flow (fill a beer can in a minute or so), if this is weak it could be sending unit, pump or pressure reg.
3. make sure all of your plug wires are on the correct spot, plug wire 1 on the number 1 location on the cap.
4. Spray some brake cleaner in the throttle body while attempting to start, and see what that does.
Have you pulled the plugs to veriify fuel is being injected? You will have pressure but if the injectors are not firing all is for nothing. This happened to me after a head gasket change. The wires got pulled loose from the plug. The connector was tight but no contact was being made. Check the wires and connector coming of the silver finned box on the passenger side firewall. It will be an insulated 2 wire white with yellow connectors.
ZONAYODA
Jul 13, 2015 07:17 PM
Poncho0206
Jul 10, 2015 06:21 PM
