tranny problem...
tranny problem...
I have an '86 4-wheel drive 5-speed yota, I went out this morning and warmed the truck up and drove to my friends house to take her to work, it drove fine till I got there, when I backed up to turn around I put it in 1st gear and eased out on the clutch pedal and the shifter popped out of gear. I put it back in gear and held it and drove on no other problems. Got her to work and it did it again, same thing. When I got home I parked the truck and figured I'd try 1st again, it popped out again but wouldn't go back into gear it just grinded and wouldn't go in gear, so I put it in second and it worked fine. Could it be something simple like changing the fluid in the hydrolic clutch or is my tranny about to drop? Thanx in advance for any help!
tranny problem...
original engine and tranny @ 140k, is it my syncro, and how hard would that be to do myself without any transmission experiance except changing fluid and filter in a chevette
it's not 'that' hard, but everything in a transmission moves.
if you're going to be delving into it to replace synchonizers, you might as well rebuild the entire thing. If you don't have the tools in your box already, get someone else to do it.
TheBFA
Feb 15, 2020 06:55 AM
live4soccer7
May 11, 2016 06:52 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
