shaking is driving me crazy!!
got a 93 toyota truck 4x4, new shocks front and back, custom built driveline, new tires , used set of aluminum rims, balanced and rebalanced, rotate tires, rotate tires on rims, front end gut says it's tires or rims, got a road force balance for 100.00 it helped a little, been dealing with this for two years, if I could sell it I would but who is going to buy a truck that shakes, this is not a vibration, this thing shakes......anyone have any ideas?????
were the rims checked for runout or out-of-round?
and what's "custom" about your driveline?
and yeah, worn suspension parts could cause a problem, particularly if the alignment angles aren't dead on perfect.
the whole truck shakes, or just the steering wheel shakes?
could be SOOOO many things, even after what you've replaced; steering-stabilizer, mis-clocked drive shaft, bad u-joints, and as mentioned above, what you you mean by "custom driveline"?
by "drive line" do you mean drive shaft?
"drive line" is more of a description of a combination of parts like the clutch (or torque converter), trans, u-joint, drive shaft, differential, axle shafts, and so on...
jasonty
41
Dec 23, 2018 01:00 PM
v_man
Jul 23, 2015 04:01 PM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
