Removing U JOINT from Driveshaft HELP
Hey I need desperate Help
I have gotten my driveshaft off my truck
now i cant get the u joint off og the drive shaft i have removed the c washer type rings and
now im trying to push the bearing through by vising a socket to the bearing and pushing it through
do you have any other tips to accomplish this step i dont see any movement starting to happen
and i used pb blast overnight
please help
please help
Glue? That's the first time I've ever heard that. My factory shop manual says nothing about glue.
What you've got are caps that are probably rusted in there. I assume you've soaked them down with PB Blaster or something similar.
I had to use a large ballpein (or ballpeen, depending on how you want to spell it) and place the yoke on a 2x4. Using a socket or something else you don't mind sacrificing as a punch, you have to beat the living crap out of the cap by placing the socket on it and trying to pound it out the other side.
Like is shown halfway down on this page: http://www.dodgeram.org/tech/repair/U_joint/repair.htm
X2...
As well, you may have to pound in one direction, flip the shaft and pound in the other, and back and forth until the caps come loose. My last job was like that. And, I've had others in the past.
There is no glue in the u-joints.
would it be too much to ask you to go out to your truck and take pictures and describe exactly how to use a right-angle grinder, or even Dremel, to cut the u-joints out without damaging the drive shaft?
Actually, I had to use my 4 1/2" angle grinder once I got them to move. I could only get one yoke off, so I simply cut through the U-joint between the cap and the main part of the + .
It can be done. Just be careful where your power cord is because you can slice through it very quickly if you're not watching. Don't ask me how I know this.
Worse comes to worse take it to a driveline shop. They are much cheaper than a stealership or even regular shop and they can pop the old out and new one in in no time. We have an awesome one here in Boulder - Boulder Driveline, and he pretty much rules... While your at it (if you go to a ship) have them check your DL balance... It can't hurt!
I usually save my do it yourself ujoint replacements for on the trail repair
Sep 4, 2015 09:27 AM
trailgoat
Aug 13, 2015 05:54 PM
Tonetrk
Aug 6, 2015 10:06 AM
