Miss in motor
Old Jun 2, 2008 | 09:56 PM
nor*cal's Avatar
Miss in motor
I have what seems to be a miss in the motor from about 1000rpms to 1700rpms it's worse when it's cold, but gets a little better once warmed.
What do you think could cause this?
Old Jun 2, 2008 | 10:01 PM
4Crawler's Avatar
Might help to give folks a clue as to what year and type of engine you are referring to.
Old Jun 2, 2008 | 10:02 PM
nor*cal's Avatar
Oh yeah sorry I'm exhausted just got home from work.
It's a 85 22RE
Old Jun 2, 2008 | 10:48 PM
pcmentor's Avatar
I just fixed a similar miss by adjusting the valves. 1985 22RE
Old Jun 3, 2008 | 04:48 AM
toytech76's Avatar
Could be anything from valves to a leaky H/G
Old Jun 3, 2008 | 06:51 AM
4Crawler's Avatar
Might start by seeing if there is any stored trouble code(s):
- http://www.4crawler.com/4x4/CheapTri...CheckConnector
Old Jun 3, 2008 | 07:25 AM
nor*cal's Avatar
The battery has been out of it for like a month before I got it, Wouldn't that reset it?
nor*cal's Avatar
How would I check the headgasket?
Old Jun 3, 2008 | 07:28 AM
4Crawler's Avatar
Yes, that would reset the ECU, but since you did not put that fact in the post how should we know that was the case. And have any codes been saved since the battery was installed and the engine actually run?
Old Jun 3, 2008 | 07:30 AM
nor*cal's Avatar
No my CEL hasn't came on.
icentropy
Sep 16, 2020 02:47 PM
Sleaker
Aug 26, 2020 06:03 AM
MMA_Alex
25
Apr 18, 2017 05:07 AM
Sep 4, 2015 09:27 AM
TDonkey
Jul 26, 2015 10:14 AM
