I don't want a lift, just better springs
Old Apr 24, 2008 | 09:48 PM
pezak's Avatar
Has anyone just installed better leaf springs, I don't want a lift just something beefy like diesel springs? I have a 84 xtra cab bone stock.
Old Apr 25, 2008 | 04:12 AM
Wardamneagle's Avatar
It is my understanding that Alcan Spring will make leaf springs anyway you want them. You might try them.
http://www.alcanspring.com/index.htm
Old Apr 25, 2008 | 01:48 PM
pezak's Avatar
thanks I'll give them a call.
Old Apr 25, 2008 | 02:34 PM
hurley842002's Avatar
Alcan is going to cost you though, might look into OME springs, not sure if they make anything with zero lift but they make heavy duty springs with very little lift.
Old Apr 25, 2008 | 06:45 PM
deserttoy84's Avatar
get old man emu springs... there good quality springs and they give you minimal lift.
Old Apr 25, 2008 | 08:48 PM
4Crawler's Avatar
Yes, the OME 2" lift springs are a good option. One reason the stock springs ride pretty rough is that you have almost no up-travel, especially up front. A little lift will give the suspension room to move and soak up bumps without bottoming out. Here is an '85 4Runner with the OME springs and I think 30" tires:
Hardly can tell it is not stock.
The other option is some replacement springs from JC Whitney, they are supposed to be fairly good.
Old Apr 26, 2008 | 12:17 AM
Guys, I'm a big fan of OME and have the them on my 85 4Runner. He said he wants minimal lift and I got 3+ inches. In fact, I had to install a drop draglink because the lift wouldn't work with my OEM draglink.
OME makes stock height kits for the 80 series landcruiser but not for the gen1 4Runners.
Here's a photo of OME's on an 85, heavy front and medium rear.
Old Apr 26, 2008 | 07:49 PM
93rustedyota's Avatar
if u want beefier springs u could do what i did i got another set of springs cut them took myn apart and added 2 more leafs so now i have 5 leafs and it does give it a little lift but i has 1500 pounds of chain that i hauled the other day and it barly even squated and its not that bad of a ride anyway
Old Apr 26, 2008 | 08:46 PM
ephwang's Avatar
I recently put OME medium duty springs on my '85 pickup and it was closer to a 3 inch lift than the 2 inch they advertise. The truck also sits a bit tail high. On my other '85 pickup I have the Northwest soft ride springs and it was a 2 inch lift. Both suspension system's ride quality were superior to the stock ride. Just don't make the mistake of using Rancho 5000 shocks.
Old Apr 27, 2008 | 02:15 AM
blue Yota's Avatar
I would get Alcan springs for the truck. I just got some for my '01 Nissan Xterra and love them. true they might be more expensive....but well worth it. My were around $240 per spring
88sasturbotoy
Jan 30, 2026 01:57 PM
Flying91
45
Apr 11, 2024 04:39 PM
Sep 4, 2015 09:27 AM
cars-guy
Jul 11, 2015 07:51 PM
Nickdigg
Jul 7, 2015 06:04 AM
