W56 grinding like crazy (Need rebuild?)
Old Apr 2, 2008 | 04:19 PM
Hazen's Avatar
I bought my 88 4runner about a month ago and have been seriously considering a tranny rebuild.
The issue is in 2nd, 3rd, and 5th. When I shift into these gears there is a crunch (No big deal, syncros maybe? Doesn't worry me too much.) But once I am in gear there is this horrible grinding noise. It gets a lot worse and more noticeable when I let off the gas. You can hear it while accelerating but once I lift my foot of the pedal it starts crunching and grinding and it is very annoying.
I've been trying to read up on this and (I'm assuming here) I think maybe I just need some new syncros and some new bearings for those gears? 4th gear is CHERRY, being thrown in to 4th sounds good and no grinding...
If I need to rebuild I was going to get Mar Craw to do it but the kit alone is 400$ and god knows how much it is to send it and get them rebuild.
Any advice on maybe overhauling as opposed to a rebuild?
THANKS!
Old Apr 2, 2008 | 04:50 PM
SEAIRESCUE's Avatar
Well, appears a bearing has gone bad which throws out shaft alignments. 4th is a magical gear. Either it will often be the noisey one or the quiet one. Both indicative of internal serious problems. Unless you know of a highly recommended manual transmission fixer, send it to Marlin. Their prices appear to be reasonable. And, no good transmission repair is complete without a good clutch repair. A bad clutch can eat new transmission syncros. You are looking at 2G's for all this work unless you do the clutch yourself.
My $0.02
Old Apr 2, 2008 | 05:21 PM
toyota_mdt_tech's Avatar
THANKS!
You have shot tranny bearings and synchros. Spendy, but fixable for sure.
Old Apr 2, 2008 | 06:15 PM
'884Runner's Avatar
Someone else recently posted with similar problems on a w56. If it were me, I would look around and find a used one from a totaled or truck with blown motor. There are quite a few of them out there, so it shouldn't be nearly as expensive as rebuilding one. They are well known for outlasting the engines, so you should be able to find a decent one cheap, but I guess you still run the risk of buying a piece of crap. However, if you find one for around $200, it'll sure save you some money.
Old Apr 3, 2008 | 07:28 AM
Hazen's Avatar
Someone is selling one for $225 But I'm thinking shipping must be a killer! It's w/ trans case and everything...
Ah well... I'll call around and try to find a specialist that can replace the syncros and bearings... I just can't afford 2k...
Old Apr 3, 2008 | 08:23 AM
MSR's Avatar
MSR
2g,s is a little steep I sell full rebuilds for 850 and shipping is only 100 on a trans, that leaves 1050 for install and clutch?
Old Apr 3, 2008 | 09:27 AM
Hazen's Avatar
If I bought a MC rebuild kit for 400$ how much do you guys think I would expect to pay to get someone to rebuild it?
pickle6415
Apr 14, 2021 06:20 AM
pickle6415
Oct 19, 2015 08:08 AM
yoterr
Sep 15, 2015 06:26 AM
langry345
Sep 14, 2015 03:36 PM
--Oz--
Sep 6, 2015 01:06 AM
