85 yota pickup e brake cable removal?
there is what they call a "pawl" @ the end of the emergency cable / hard case (inside the cab) . it is simply pressed in . you need to unbolt the leaver case (park brake pull handle and casing) so you can work on it ..12MM bolts , 2 of them I think ? (punch and hammer work good for removing the pawl).
punch out the "pawl " it's the metal piece that actuates the brake light switch .
once the "pawl" is out .. you can remove the cable .
voiddweller
19
May 2, 2016 09:10 PM
