gas milage
Old Mar 7, 2008 | 10:22 AM
rhino66549's Avatar
gas milage
I have a 93 toyota 3.0 auto 4x4. I get like 12 mpg. I have 31x10.50's on it and no lift. I have a venom 400 chip and cold air intake. My ID plate says that my differential codes is B04B. I have 4.56 gears and was wondering how I could get better gas milage. thanks
Old Mar 7, 2008 | 10:23 AM
PoleVaulter95's Avatar
swap in a 5spd seems to be the best way to make better mileage on a 3.0
Old Mar 7, 2008 | 10:38 AM
ToyoRunner94's Avatar
i would suggest the routine maintenance. ive had two 1994 4runners and have gotten about 16mpg out of both. check the spark plugs, air filter, fluids, and just try going a little easier on the pedal. i drove mine mildly to aggressive and still got about 15-16.
Old Mar 7, 2008 | 10:44 AM
rhino66549's Avatar
I have had the plugs and wires changed. I have the cold air intake so I just clean it out and reoil it. I just had a new block put in it and had all of the belts replaced. I was just curious if the gears would effect it that much.
Old Mar 7, 2008 | 12:24 PM
rhino66549's Avatar
does anyone have any other suggestions
Old Mar 7, 2008 | 03:47 PM
dcg9381's Avatar
12mpg isn't great.
How's that Venom chip work? Tried running without it?
I'd check on the function of the 02 sensor - make sure it dithers at cruise... If you're mainly city driving, drop a tire size.
Old Mar 8, 2008 | 04:20 AM
rhino66549's Avatar
The venom chip is great for the extra power. If I turn it off i don't have enough power to drive on interstate. I do to much driving in pastures to drop a tire size.
Old Mar 8, 2008 | 04:46 AM
s_wall98's Avatar
You've definitely got something wrong if you can't drive on the interstate without a chip. I've got 33x12.50 MTs, with 4.56s and very rarely have problems on the interstate here in mountainous NE TN / Western Carolina...and get anywhere from 15-18mpg
Old Mar 8, 2008 | 10:40 PM
Matt16's Avatar
If you don't offroad much, 29" tires seem to get good mpg. I spoke to someone with a stock 3vze on 29" tires and he got about 17-18mpg.
pickle6415
Oct 19, 2015 08:08 AM
larrys93pickup
Sep 17, 2015 07:05 PM
gp66
Sep 14, 2015 12:10 AM
Boomer8404
Sep 10, 2015 09:01 AM
northwalker
Sep 3, 2015 12:21 PM
