electric rear diff locker on 99 runner
Old Feb 25, 2008 | 04:50 AM
99runnersilver's Avatar
Hi all. Im new on this board and to the toyota scene.
anyway, i found a writeup for disabling a safety mechanism invloving the push button rear diff lock. the writeup is for a 97 4runner, and by grounding out a wire at the ecu, it allows you to lock up the rears while in 2wd, 4hi, and 4lo- not just 4lo. can i use this same writeup/process on my 99 4runner?
Old Feb 25, 2008 | 07:18 AM
Elton's Avatar
it should be the same
Old Feb 25, 2008 | 07:30 AM
X-AWDriver's Avatar
Yes,it's the same.
Old Feb 25, 2008 | 08:34 AM
heavydm's Avatar
can someone post the link to that article about grounding the ecu ?
thx
Old Feb 25, 2008 | 11:39 AM
Elton's Avatar
http://www.hboss.net/4runner/locker_safety.htm very simple should take no more than 10mins just make sure you ground the wire going to the plug
Old Feb 25, 2008 | 12:42 PM
heavydm's Avatar
thx Elton
Cheers,heavy
Old Feb 25, 2008 | 04:39 PM
Hal G's Avatar
I believe this is called the gray wire mod. If you do a search for thi it should give you the post. good luck Hal
Old Feb 25, 2008 | 08:21 PM
Elton's Avatar
for the 4runners im pretty sure its a blue/red wire
Old Feb 27, 2008 | 03:02 AM
KZN185W's Avatar
Hi,
Is the ECU referred to in the write-up above the engine ECU? Or is there a separate ECU for the rear diff lock?
Thanks!
Team420
Jan 12, 2021 04:57 PM
merc1100sc
Jun 26, 2015 05:24 PM
cchinny
Jun 25, 2015 08:11 PM
HBoss
15
Jun 20, 2002 05:28 PM
