How easy is it to remove the rear fender panels on an 88 4runner?
Old Feb 17, 2008 | 04:29 PM
alcarames's Avatar
Is there cutting involved and welding to put on the new ones? Or is everything just bolts? Anyone have any pics?
Old Feb 17, 2008 | 04:52 PM
AxleIke's Avatar
You have to cut the old one off, and weld or glue a new one on. If replacing with metal, welding would be better.
I guess you could bolt it on, but it would look really bad.
Old Feb 17, 2008 | 04:56 PM
881stGenRunner's Avatar
here you go man, check out this thread -
https://www.yotatech.com/forums/f116...-redux-126069/
Old Feb 21, 2008 | 10:01 PM
4Rocker's Avatar
It is an involved process cutting all of the old spot welds off, grinding surfaces flat, fixing rust, and welding on new ones:
If you have not welded thin sheet metal before, it can be tricky at first.
Old Feb 21, 2008 | 10:03 PM
sloppy85toy's Avatar
good job mad props
Old Feb 24, 2008 | 08:23 PM
hudsdad08's Avatar
just wondering how long all that took you to do?
Old Feb 27, 2008 | 02:54 PM
4Rocker's Avatar
I did that back in high school, so it wasnt a very speedy process. A couple weeks from start to finish maybe? It will depend on your prep work, how you weld it, and the amount of rust you need to repair underneith.
Old Feb 27, 2008 | 04:02 PM
hudsdad08's Avatar
I didnt want to spend the time and money to buy full replacement panels but it would of been nice
arlindsay1992
Jan 23, 2024 01:34 PM
cchinny
Jun 25, 2015 08:11 PM
4runnerx3
Jun 24, 2015 01:44 PM
Taz22R
Jun 21, 2015 04:44 PM
JaredL
Jun 16, 2015 04:47 PM
