my v6 is running way to rich
Old Feb 14, 2008 | 10:24 AM
4runnerguy's Avatar
my 2nd gen v6 3.0 is running way to ritch and how can i ajust that.
Old Feb 14, 2008 | 10:42 AM
dcg9381's Avatar
OK, start with the basics:
1) Have you checked it for codes?
2) How do you know it's running rich?
3) Is it running rich at idle or during cruise?
4) Have you ever adjusted / opened / or tweeked the AFM?
5) How long has it been doing this?
Old Feb 14, 2008 | 11:18 AM
4runnerguy's Avatar
i can smell it and no i never touched the afm for about a month
but how do u change it
Old Feb 14, 2008 | 02:06 PM
dcg9381's Avatar
"I can smell it"
Do you have a cat on your truck? If not, you're going to smell rich all the time.
Even if so, with a cat that's not heated or that might be going bad, you'll be able to smell the fuel under normal conditions.
There is a wheel on the AFM, at least 22RE - and I believe the V6 that can be rotated to impact the base mixture. Don't touch it if it hasn't been messed with.
IF your MPG is OK and you're not spitting black yuck at idle, it's likely that you're not rich... Do you have a sniffer test where you are?
Old Feb 14, 2008 | 06:24 PM
4runnerguy's Avatar
ya i just put in a new magnaflow cat and a catback.
and my mpg are not good
Old Feb 14, 2008 | 07:17 PM
dcg9381's Avatar
Whats your MPG?
What did you do to the AFM originally?
Old Feb 15, 2008 | 04:53 AM
wcc_71's Avatar
i have stock exhaust and my 3.0 uses alot of gas and idles rough.. still waiting for some suggestions from everybody
Old Feb 15, 2008 | 07:24 AM
dcg9381's Avatar
Whats your MPG?
Do you have black smoke or black stuff coming out of the exhaust at idle?
Are your wheels/tires/gears/ stock?
You said you "messed" with the AFM - what did you adjust exactly?
Doug4320
Mar 24, 2018 10:11 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
tj884Rdlx
Aug 28, 2015 12:04 PM
coffey50
Jul 28, 2015 10:55 AM
calderp
Jul 27, 2015 09:58 AM
