V6 T-case Xmembers
Old Feb 12, 2008 | 10:32 PM
Kiff's Avatar
V6 T-case Xmembers
So I'm on the hunt for a x-member for my truck, I really like the style Front Range Off-Road has, that bolts to the back of the t-case, but they don't make anything for the V6 only the gear driven cases. Anyone know of a company that does that style but for a V6 case? or is it just better to get a budbuilt style?
Old Feb 13, 2008 | 06:38 AM
tc's Avatar
tc
I like my Budbuilt.
With the FROR xmember, you still need a skid under there IMHO, so why not just incorporate it into the crossmember (aka budbuilt design)?
Old Feb 13, 2008 | 05:14 PM
Kiff's Avatar
is the trailgear one the same as budbuilt?
Old Feb 14, 2008 | 08:57 AM
tc's Avatar
tc
Probably - they're kinda known for stealing people's designs and having them produced off shore for cheaper...
Old Feb 14, 2008 | 02:03 PM
fillsrunner4's Avatar
Your best bet could be to mod an already made one or just make your own. You can make a sick one from sratch
Old Feb 14, 2008 | 03:24 PM
bigarms23's Avatar
o have one from sky manufacturing and havent been disappointed with it
Old Feb 15, 2008 | 02:23 PM
Kiff's Avatar
Does anyone know if the dual case x-member from trail-gear will work with only 1 case?
Old Feb 15, 2008 | 07:27 PM
Elvota's Avatar
My guess is no... probably won't line up at some point, either at the frame or T-Case mount locations,
But I do not know what TG is considering for dual cases behind a V6? I assume they are putting dual 4cyl cases behind it with an adapter to the R150 tranny. So in actuality, their crossmembers would be set up for 4CYL cases... not a V6 case.
TG or Waskilly would know.
Out of curiosity... why do you want a dual case crossmember for just one case in the first place?
Old Feb 15, 2008 | 07:37 PM
Kiff's Avatar
Well I plan to setup duals next winter, but I am in need of a new x-member now, so figured I'd kill 2 birds with 1 stone.
Old Feb 16, 2008 | 08:05 AM
tc's Avatar
tc
I thought you could use the factory crossmember with duals ... or a single case crossmember, but it wasn't as strong/secure.
Why do you need a crossmember so bad Kiff?
Old Feb 16, 2008 | 10:33 AM
Kiff's Avatar
i smashed mine pretty good wheelin, now it's got a crack in the bottom and I lost 1 side of the rubber mount. So I need to get a new t-case mount anyways, going by my motto, if it breaks make it stronger
Old Feb 17, 2008 | 08:49 AM
tc's Avatar
tc
Yeah, that's a problem... you should call Bud at Budbuilt and discuss using a dual case crossmember with only one case with him...
ClintonP929
3.4 Swaps
64
Jun 13, 2017 01:46 PM
Rowdydudeman
Nov 26, 2015 02:17 PM
Rickstwowheels
Sep 18, 2015 03:48 AM
priest16
15
Aug 6, 2015 07:43 AM
