Should I replace the rear main seal??
Old Jan 7, 2008 | 11:51 AM
mtrdrms's Avatar
I am in the process of a clutch job on my 89 4runner 3.0 and I have the flywheel off but I was wondering if I should replace the rear main seal while I have a good shot at it? It looks fine and its not leaking at all. I would be pretty upset if I put it in wrong and it leaked but I guess I would also kick myself if this one started leaking in a few thousand miles.
thanks
Andy
Old Jan 7, 2008 | 12:09 PM
TORTIS's Avatar
no leave it alone, it will give you something to do in a couple of months.
if you don't replace it, you will hate your self later...
Old Jan 7, 2008 | 12:13 PM
mtrdrms's Avatar
haha. good stuff.
Old Jan 7, 2008 | 12:18 PM
Albert.G's Avatar
while your there...i hope you do... its like taking a crap and not wiping your bum...and putting on 3 layers of clothes...then putting on a snow suit...then thinkin...damm i shoud have really wiped
Old Jan 7, 2008 | 12:27 PM
tampabayota's Avatar
trust me it is wise to do it now
TNRabbit's Avatar
x4 to the above; it's really easy at this point and it will NOT be later!
Old Jan 7, 2008 | 12:33 PM
MudHippy's Avatar
Alright, fine. You guys convinced me too. I happen to be in the same boat and was wondering the same. Guess I better go pick one up. My clutch shouldn't be here for a day or two anyway, so I'd best take care of it now too.
Old Jan 7, 2008 | 04:50 PM
ewong's Avatar
I do it every time the trans is out...
Old Jan 7, 2008 | 05:14 PM
SEAIRESCUE's Avatar
Really dumb move if you don't do it during a clutch change. Clean the crank surface really good with brake cleaner and put a light coat of grease on the seal.
Old Jan 7, 2008 | 07:08 PM
TNRabbit's Avatar
I use STP oil treatment on the seal. Stickiest damn lubricant I've found!
Old Jan 7, 2008 | 07:51 PM
84sr5yoty's Avatar
Hell, replace the front seal on the trans too. I replaced my clutch last year and now the front seal on the trans is leaking
Oh well, what can you expect from a 24 year old seal with 200K miles.
Old Jan 7, 2008 | 08:00 PM
CoedNaked's Avatar
Now this is BY FAR the best analogy to explain WHY you should do the rear main seal while you're doing your clutch, that I have EVER HEARD.
I would definately do the rear main if I were you.
Old Jan 7, 2008 | 08:05 PM
YotaJunky's Avatar
Originally Posted by tortis
no leave it alone, it will give you something to do in a couple of months....
Old Jan 8, 2008 | 03:44 AM
mtrdrms's Avatar
Well I got the seal and dam when did they go up to 28 bucks! Oh well Im off to put it in. Thanks for all the advice guys!
Andy
warrenjcarlson
Jul 22, 2016 11:47 AM
voiddweller
19
May 2, 2016 09:10 PM
jennygirl
Nov 17, 2015 11:24 AM
Alaskan91
Sep 21, 2015 04:39 AM
cchinny
Jun 25, 2015 08:11 PM
