my clutch is slipping
ok so my clutch started to slip yesterday i think. if i am moving and rev above 2500 it continues to semi freely without accelerating. what can i do some one told me to adjust it. i don't know what or how.
I use Exedy stock replacements with good results. I just pulled mine the other day after about 18K miles and a year and a half (and a good amount of wheeling) and it really didn't have much visible wear.
If you wheel the heavy duty might be good. I found after a long day on the trail (6 hours) the stock clutch would start to "Fade" or slip. I am pretty hard on clutchs tho
No experience with the ceramic.
right now the truck only sees light wheeling since it's mostly stock
as soon as i get some money and find me a nice taco this will become a trail rig
i'm thinking the ome one from wabfab right now
is there anything else i should get if i'm replacing the clutch?
J
I would reccommend pulling the flywheel and getting it surfaced. Every clutch I have replaced I do this.
Also check the rear main seal, If the oil pan is leaking replace it, while the tranny is out it is a lot easier to do this stuff too.
kawazx636
Oct 6, 2021 03:03 PM
primordialbeast117
Dec 19, 2015 12:23 PM
smilen724
13
Nov 8, 2015 04:11 PM
hiluxinargentina
Sep 30, 2015 11:12 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
Pretty much oem but with higher clamping force
