Killer Vacuum Leaks
Killer Vacuum Leaks
I have an 88 toyota pickup with a 22re engine i have fallowed all the vacuum diagrams online but i am still missing a few. the book doesnt cover all of them. can anyone please post pics of the same efi intake manifold. i have an open hole that none of the other vacuum lines will fit onto (the hole is too wide) thank you
Some pix. on my web page:
- http://www.4crawler.com/4x4/CheapTri...ine_Pix/1.html
Best thing is to get a factory service manual (FSM) and check out all the chapters and come up with how things are supposed to be connected and what each line is supposed to do. That is how I did my engine.
thank you guys the one i need is only in one of the pics off pirate but i cant tell where it goes i looked all under the efi manifold but no clue where can i check out one of these factory service manuals
Go to www.ih8mud.com and look in the FAQ there are links to FSMs for a range of years. They are also on 4x4wire and may even be here as well.
http://forums.bauchan.org/portal/downloads.php
http://www.toyotanation.com/forum/sh...37&postcount=2
http://www.ncttora.com/fsm/
ya so i found out that it actually wasnt a vacuum leak and it turned out to be the egr valve i got to figure out where to put the end of the vacuum line goes could it affect my idle that much it sounds like its retarded but all the timing is on i checked
i fixed all my vacuum lines but now i am stuck with an exhaust leak but dont know where ist coming from. i checked all the egr bolts and the manifold bolts they are all tight. the plate on the back is tight as well i am stumped
