22R exhaust manifold gasket quality
Old Oct 18, 2007 | 10:29 PM
the_supernerd's Avatar
I need to get a new exhaust manifold for my '88 22R pickup. I see some kits come with all the gaskets and will save me money. Some of these are cheap kits on eBay. Does anyone have recommendations on gasket brands? I would rather spend a little more and get a quality gasket than get something that is going to blow out soon. Beck/Arnley gaskets are on sale at Rockauto, and I am also wondering about Dorman.
Old Oct 18, 2007 | 10:33 PM
chroad's Avatar
Have you priced the difference between these brands and getting one at the dealership? What's the quality difference between an aftermarket and a Toyota OEM gasket? Are you getting a new header? I think most headers come with the gaskets you need.
Old Oct 19, 2007 | 04:58 AM
natedawgg94's Avatar
depends on where you get the header seen some that came with headers i wouldn't even attempt to try. i've used some from autozone with luck so far.
Old Oct 19, 2007 | 08:08 AM
n4ynu1010's Avatar
OEM Baby unless your have or are going with a header then use the header manufacturers gasket
Old Oct 19, 2007 | 03:03 PM
I will save a lot of money if I buy a kit, which appears to be a Dorman brand manifold and gasket. If they are really bad quality then I will go with OEM. Has anyone had experience with the Dorman brand?
Old Oct 19, 2007 | 04:02 PM
superjoe83's Avatar
if you want one that will NOT leak here is your answer:
http://catalog.remflex.com/product_p/rf7002.htm
ive been running these on my 22re and my SB Chevy tow rig, never had a problem!!
Old Oct 19, 2007 | 04:11 PM
n4ynu1010's Avatar
Manifold Gasket
Nice to know , will check them out
Old Oct 19, 2007 | 05:08 PM
Georgiadave's Avatar
When i did my engine, the gasket in the kit was clearly not the same quality as the Toyota OEM gasket. I used a Toyota gasket in several locations where the kit gasket looked marginal. On the other hand, replacing a bad gasket is not that big a deal, the kit gasket may work fine.
Old Oct 19, 2007 | 05:13 PM
n4ynu1010's Avatar
We are speaking of header gaskets , I think
Old Oct 19, 2007 | 07:01 PM
SCYOTA's Avatar
I second the Remflex idea. I just ordered that gasket a few days ago from a local auto parts store for $20. The nice thing about them is that they are about 2.5 mm thick so they can account for any warpage in your header.
Old Oct 19, 2007 | 07:13 PM
misterzee's Avatar
X2 on the ramflex
X2 on making sure your manifold is not warped. I take mine to the machine shop and get them planed.
Also, make sure all your studs are there. HeliCoil if necessary. Don't neglect the support bracket down on the bell housing. Lots of times ppl don't clamp the pipe back down, that excessive vibration will stress your manifold connection.
Old Oct 20, 2007 | 12:12 PM
Those remflex ones look good. I think I will order one. I just bought a new exhaust manifold and I know that all of the studs are on the truck. Would there be any reason to install new studs? The support bracket is there, but not attached. I plan on re-attaching it and checking the cat to make sure it is not clogged. Thanks for all of the advice!
Old Oct 20, 2007 | 10:03 PM
SCYOTA's Avatar
If the studs are in good shape I would leave them alone. You may want to replace the lock nuts because they tend to loose their locking ability if they are reused.
Old Oct 21, 2007 | 03:11 PM
n4ynu1010's Avatar
Headers
I always used stainless nuts and lockwashers on the small blocks , may be a tad expensive but the puppys won't rust .
I used to used the self locking ones (also stainless ) but then I realized after a few times on and off they weren't so self-locking anymore so I used the lockwashers and was even guilty of using a narrow stainless flatwasher as well and could be found on the first installation filing a flat edge on that washer for some of those nice tight stud/pipe tolerences but of course this is when large lizards roamed the earth and the natives used primitive carbueration .
cars-guy
Aug 16, 2020 06:59 AM
dumpster84
Apr 30, 2016 06:03 AM
tj884Rdlx
Aug 28, 2015 12:04 PM
Coreyr384
Jul 10, 2015 11:13 AM
87blyota
Jul 10, 2015 04:31 AM
