can i put 265/75/r16's on my factory 2002 taco??
Old Jun 29, 2007 | 07:07 AM
mkgarrison5's Avatar
hey guys i currently run 245/75/r16's and was thinking of going up a size 265/75/r16's.. i have no mods on this truck, everything is stock. can i run this tire without rubbing and etc??
Old Jun 29, 2007 | 07:23 AM
norcalsvx's Avatar
if it is a 4x4 you can
Old Jun 29, 2007 | 07:31 AM
yes it is a 4x4.... will it rub on tight turns or rub the fenders while flexing?
Old Jun 29, 2007 | 08:19 AM
Tacoclimber's Avatar
I never noticed any significant rub when turning, and you'll only rub when you're completely stuffed in the rear. I ran my 03 like that for a couple years, with no problems.
Old Jun 29, 2007 | 08:30 AM
taco climber are those tires in your avatar 265/75/r16's??
Old Jun 29, 2007 | 08:31 AM
anyone have any pics of their 265's on their factory tacos??
Old Jun 29, 2007 | 08:39 AM
Naw, sorry bro. Those are 285's...
I think in my truck's profile I have a pic of my truck sitting on 265's.
Old Jun 29, 2007 | 08:47 AM
where is your trucks profile?
Old Jun 29, 2007 | 08:55 AM
CJ's Tacoma
Try that.
I think in all those pics I had the 3" suspension lift on, but I put the lift on after I put on the tires, and I don't recall any issues other than what I already posted...
Old Jun 29, 2007 | 09:17 AM
nice picks... what is the differenc in 265/75/16 and 265/70/16's ???
Old Jun 29, 2007 | 09:34 AM
Slightly different ratio in the size of the tire. A 265/70r16 is roughly a 31/10.50 (depending on the manufacturer). A 265/75r16 is roughly a 32/10.50. It's an approximate comparison, but that's basically it. You'll find that the 265/75's fill up the wheel well a little nicer, but with no major issues. When I lifted my truck, it still looked pretty decent. But be careful... Once I lifted it, then I wanted to go with a little bit bigger tires. I went to the 285's. But once I did that, I wanted a little more room for those 285's, so I put on a 2" bl. It's an addiction, man! Seriously, I'd say go for it.
Old Jun 29, 2007 | 10:17 AM
oh lord i cant have an addiction.. i cant afford it lol.. i make teacher's pay.. just the bigger tires will do. ill run a set and if like it ill stick with it if not ill go back down to the 245/75/16... the 265/70/16's are the same height but wider by one inch. and the 265/75/r16's are an inch taller and wider than the 245/75/r16's
Old Jun 29, 2007 | 10:23 AM
I think you'll like it...
Old Jun 29, 2007 | 10:34 AM
thanks man!
Old Jun 29, 2007 | 10:41 AM
thanks man!
No worries. Any idea what brand you're going with? I went with BFG's because of their reputation in the kind of terrain I wheel in here in the desert, but for you over on the other side of the states, there's a handful of probably better choices. Nitto's are pretty awesome from what I've heard, and a lot of guys like the Kumho AT's.
Old Jun 29, 2007 | 10:51 AM
yeah either the kumho AT (kl-78's) or the terra grapplers in 265/75/16.. best tires for the $$.. i drive alot of highway miles.. ALOT! i hardly drive off road but when i do its pure red mud and BF at's are not great in red mud. gotta love good ole carolina red clay!! keep the tires moving fast or your butt gonna get stuck!!
Old Jun 29, 2007 | 10:59 AM
Yeah, the AT's aren't the best in that sticky mud. We have a lot of pointy plants and sharp rocks around here, so the 10 ply tread and 3 ply sidewall of the BFG's make them worth it...
Good luck with your tires, bro.
Old Jun 29, 2007 | 11:12 AM
yeah good point on the sticky things. luckily we dont have much of those tire popping monsters.. just nails and sharp rocks.. thanks man!
Old Jun 30, 2007 | 03:50 AM
RETRO's Avatar
mkgarrison5 here is my 04 with 265/75/16 on it..I have some rub when I turn left and in dips..It is very minor you will have to remove the mudflaps if have not already did..
Old Jun 30, 2007 | 07:35 AM
Good call on the flaps. I totally forgot about that. I also had to remove mine...
Boy, that picture takes me back. Looks just like mine did, only I have the Lunar Mist. Gosh, these trucks just look cool....
