Speakers in your 2nd Gen 4Runner
Hey, I was just wondering, where does everyone put audio speakers in their 2nd generation 4Runners? I've heard that they came with a factory 8 speaker system, but I have spent countless hours removing panels, measuring depths, and I have even considered speaker boxes, because I have no idea where to add more speakers, or how to add bigger speakers. Any help will be great, pics of your install would also help a lot. Thanks.
well, i am building a fairly extensive audio system in my 4runner.
I have 4inch speakers in the dash, 6x9's mouneted under the rear pannels(requiers SOME trimming, looks stock, tweeters on the rof in the rear.
i will soon be cutting hole in all four doors for some 6.5 or 8 inch mid bass speakers. all the others run highs and i have a kick ass sub setup.
This is what I did.
https://www.yotatech.com/forums/f96/system-install-my-rig-95-4runner-116183/
I didn't want any amps showing and like the factory look to hide the quality components.
Go to a stereo shop, not BEST BUY OR CIRCUIT CITY, and listen to different speakers. What is good for the goose is not always good for the gander.
Case in point - I listened to the Polks and Infinity reference 4" speakers. To me the Infinitys were too tinty in the high frequencies and lacked tone in the base end. I liked the Polk's sound and got those. Everyone has a preference to sound qualities and each manufacturer does it differently, because there are trade offs.
I have two 10" Pyles for subs and they can vibrate my teeth! The mid-bass speakers will not add much in bass sound pressure, but it would be alright to say I have ummteen million speakers around and two up your @$$ (if you have them under the seats also), but it is just what everyone wants to do that makes them happy.
I went with a simple Sony HU that had an AUX input for my XM SkyFi2. I ran from the HU to the main amp and then from there to the sub-amp & used the amp's X-over. You can build your own box for $20 worth of MFD board and spend $60-80 on 12" Pyle drivers that will blow your mind. Unless you are in a competition for prize money, you don't need to spend $1,000+ on subs & a box, when you can do it for $80-100 yourself and have better quality sound.
Research, listen to speakers and figure out what you want it to be when you are alone in the car. That is what you should do and then show it to your friends when you are done. Don't do something because your friends said to do it. It won't make them like you more.
Osiris
Osiris
Ok, So I finally put new speakers in the back of my 4Runner. I used the stock little boxes, still, but modified them to accept a 5.25" speaker. The install was so clean, I was amazed. Removing the rear panels was a PITA as always, but I kinda had fun making those 5.25"s fit back there. In case you are wondering, they sound great, and they fit PERFECT. If you need to know any details about this install, I'd be happy to coach you along with it. Sorry, I didn't take any pics, but if you can imagine the back of a stock 2nd Gen 4Runner with the panels on, that's what it looks like still, just with bigger, badder speakers in the back. It looks completely stock from the outside, and even inside, it's a clean install. I didn't take any pics, and I'm not about to tear the back of my Runner apart again just to snap some, so sorry. I'll take some when I get an amp hooked up to em.
my advice would be to upgrade your front soundstage and put a clean single sub in the back. A couple rules of thumb for stereo installs....your soundstage should ALWAYS be in front of you as if you were at a concert, putting your best speakers in the rear is like standing in the bathroom at a show. If possible left and right speakers should be as close to equal distance from your listening position as possible, meaning the lower corners or kcik panels are about the ideal location, speakers in places like headrests and high in the doors means one speaker is ALOT closer to your ear than the other. Bass is non-directional meaning put your sub anyplace, though the direction it fires may affect the sound ie: into a corner etc so try a few differant placements. Rear speakers should be for fill only providing ambient sound like your rear speakers in home theater. Heres a pic of something that is made specifically for YOUR truck and gets you most of what you want with minimal work. Q forms available at crutchfield.com
Here's how they calculated 8 speakers:
Tweet and mid in dash (like plate separates)
Full range in back side panels
Tweets in roof panel
If you're interested in truly the best sound, especially imaging - kickpanels (like the Qforms pictures above) are the way to go. Otherwise, just throw some 6.5" coaxials in the bottom of the doors and call it good.
x2 for the listening to different speakers - everyone's taste is a little different. Be sure JL Audio is on your list to audition though.
Im running my 6.5" Dynaudio components in kick panels (q-logic, they were temporary til I built fiberglass one.....that was 4yrs ago...
BTW if you do want to run kickpanels I suggest 5.25 components, I think they are better suited for small kicks.
)BTW if you do want to run kickpanels I suggest 5.25 components, I think they are better suited for small kicks.
I put 5.25" speakers in the rear, and I realize they do more for fill than anything. But they are a definite improvement over the crappy 4" stock speakers. I believe those things you have are called Q-Form's. I have looked into those, and I was scared away from buying them by the price, I really think they are cheap compared to building your own....time is money
and the question of how much leg room I'll have to give up to cram them in there. Keep in mind I have a 5 Speed, so I will have to clutch. Do you have any pics of your driver's side with the Q-form? I dont have pics or a clutch my trucks an auto. people have posted they do not interfere with manuals
Also, How hard was the install- of the speaker, and the Q-form itself? pretty simple considering its made for a 2nd gen and I have a 1st gen
Did it come with a wiring kit?no speakers comewith wires q forms are just plastic
Was it difficult to wire it into the rest of your system? no harder than wiring speakers anyplace else. I have installed lots of stereos so I think its easy
Are you running an amp with those? Would you recommend these? I am runing an Xtant 4 chanel amp....its pimpalicious
Speakers in Rear
Ok, so I figured out the rear speaker situation. I ended up modifying the rear boxes to accept a 5.25" speaker. I did this a few months back(November), but I didn't bother to take any picures, but I was digging through storage, and found two of the factory speaker boxes, so I figured since it was SOO easy to do, that I'd take some pics and let you know how to do it. This is a great beginner's upgrade, or budget upgrade, or starting point, because it doesn't take any mechanical knowledge, other than how to saw and file.
This is the line where I sawwed off the excess from the side (NOTE: Remove anything that is screwed onto the box around where you are working before you start cutting)
This is what it would look like when the sawwing was done
Now this is another view, from the front. This is for referance
This is with the center blacked out, no cutting yet.
This is approximately what it would look like after completing the sawing, and filing.
After you get done sawing, you will want to file away the excess plastic, so you have a mostly smooth area surrounding the speaker. Vacuum or blow out the plastic "dust" and find your self a 5.25" speaker to install. If you find that there are "high spots" along the inner circle(the part that you were filing), and your speaker doesn't fit, just mark those with white out, or a sharpie, and file them down so your speaker will fit. This mod is free, assuming you have a course file, a saw of some sort, a sharpie(or whiteout) a 5.25" speaker, and about 20 minutes start to finish once you get those damn back panels off. If you have any questions, just ask.
Please whatever you do dont start chopping holes in door panels and stuff......these parts are getting harder and harder to find and it really irks me to have to replace them (from POs hack jobs) to restore to stock.... Thanks in advance
