Speakers in your 2nd Gen 4Runner
HEY WHAT FUN ARE YOU??? tryin not to chop holes in anything, but come on, 4 inch speakers and 5 in speakers in the rear, you cant hear shiat in there...
i don't know what size the back speakers are in mine, but they look stock.
The previous owners put some jbl's in the front and the sound is alright, i wish it could go louder. It is perfectly fine if the windows are up, but when you are on the highway with the windows, you tend to hear wind noise more than the music. I am not aware of any tweeters in the back, but like belize said, the 90-91 don't have them.
#25
All you need to do is drill some new holes through the backer board.
Be careful you don't try to drill through the vinyl skin though the drill will grab it and tear it, what you want to do is cut a small X with an exacto knife or punch through with an awl and the remount the map pocket. If you have the carpet you don't have to worry so much but you should still use an awl to punch through the carpet surface.
Hope this helped aviator.
#26
When you remove the door skins you will see that the map pocket is held on with screws and is located with about four larger pins.
#30
I won't be the first to admit that removing both rear panels is a PITA. Although there are much worse things I could be doing to my car, it's still not something I look forward to. It's pretty simple though.
I like the custom work from the pics, but I don't think I could ever bring myself to molest my door panels. Maybe "molest" is too strong a word, since your custom jobs seem to look good.
#31
Replaced four stockers with 5.25", powered by the HU. Added a custom box with four 6x9's, 80oz magnets on each. Switched Fosgate power from under the driver's seat. Box faces rear, idea robbed from my old wakeboard boat. Will make for one hell of an outdoor bbq...
"Battery" sounds so good from behind the thing...
Neighbors don't like it thus far.
#32
1 Post
if you want clear and nice heres my set-up btw dont flame untill your ears blead from hearing everything even the backround music in my rig
blown front speakers (stock size)(blown cause then they dont make bass notes)
stock rears
eq with no bass but all highs
a RF T1 15in in a custom made box that i built (at the shop i use to work at)
a cheap 500w sub amp(mono chanel)
and a jvc avx-2 hu
you want a sound clip you say well ill see what i can dig up here.............
ok ok ok i dont have my computer so i cant show the video of when the amp was good but heres a video of when i smoked my amp if it helps lol
just to show you how it playied and yes the radio has a amp shut off feature so i dont think theres any music playing in it
http://vids.myspace.com/index.cfm?fu...deoid=11356368
ok if it dont play just go to my myspace and look its under my videos
stock rears
and a jvc avx-2 hu
#33
stock rears
and a jvc avx-2 hu
stock rears
and a jvc avx-2 hu
#37
#38
1 Post
ok just a update i still have the blowens up front but now i have one 6X9 on the pass side in back and the other stockie on the drivers side sounds good with a lil bass bump to it lol
and yes im a redneck allways have allways will!
#40
Replaced those stock 4''s and the back 5.25s with some kicker 4s and um...i forget the other brand boston something and added these.
2 10'' JBL subs. They are under powered but they still hit hard when i turn em up.
