Difference between V6 and 4 Cylinder brake calipers ???
Old May 19, 2007 | 01:52 PM
TomThumb's Avatar
Just wondering if there is a difference between 4 Cylinder and V6 4x4 pickup brake calipers and how to tell the difference. The reason I am asking is because I need to replace the drivers side and the local scrap yard is not sure what model it came off of. I can?t remove mine because it is the only thing I have to drive right now.
Thanks for the info.
Steve
Old May 20, 2007 | 03:56 AM
TNRabbit's Avatar
There is definitely a difference between them; the V6 calipers are much larger/more robust and they are NOT interchangeable. Which vehicle do you have? MarlinCrawler & WabFab have very nice remanufactured ones WITH pads for $119.
Old May 20, 2007 | 05:07 AM
91 4Runner's Avatar
V6 are 2 large pistons (2" if measured on the tire side of the caliper) and 4cyl has 1 large (2") and 1 small pistons (1.75" measured from the tire side of the caliper)... I just went and measured for you as I have both.... So if you pull your tire you'll see either 2 of the same sized pistons or 2 different sized pistons..... Hope this helps...
Old May 20, 2007 | 05:31 AM
TNRabbit's Avatar
Actually, the V6 has FOUR pistons...two on each side.
Old May 20, 2007 | 05:38 AM
waskillywabbit's Avatar
V6 IFS calipers have a larger body with the "fins" on the outside and have (4) large pistons
4 banger calipers have a smaller body and have (4) pistons - (2) large and (2) small
They both will work on the same vented rotor and most of the parts are interchangeable.
I have the V6 IFS up front on my 85 and the 4banger IFS on the rear, both on LC SFA vented rotors, thus most of my brake parts are interchangeable and I only need one spare.
http://www.wabfab.org/products/brakes/brakes.htm
Old May 20, 2007 | 05:47 AM
Angus1's Avatar
could you tell me more about the 4 banger ifs disc on the rear?
Old May 20, 2007 | 06:01 AM
I have done a full floater rear axle conversion on my 85 to make it possible.
http://www.4x4wire.com/toyota/reviews/fullfloater/
Old May 20, 2007 | 06:12 AM
Angus1's Avatar
Thanks
Old May 20, 2007 | 06:41 PM
TomThumb's Avatar
Thanks for the info everyone. It was a big help, going to a scrap yard to get a used one for 25 bucks. I just need to get it stoping then i will worry about new V6 Calipers as an upgrade. Money is kind of tight
TheBFA
Feb 15, 2020 06:55 AM
Lons81
Nov 23, 2015 09:25 AM
Odin
Sep 26, 2015 06:56 PM
83
18
Sep 21, 2015 06:15 PM
mxdw88
Sep 20, 2015 03:13 AM
