Lift a yota?
Old May 18, 2007 | 01:50 PM
yotamanmn's Avatar
Lift a yota?
I have a 93 pu, and i want to lift it. it will still be my daily. My question is what tire size are you running, with what gears, and what are your miliage? Any comments on a lift? Thanks.
Old May 18, 2007 | 02:00 PM
hanksyota's Avatar
before you get flamed to death try the search button. there are way too many options and opinions. but i am currently running stock 1996 tacoma with stock 410 gears and get 20-21 mpg combined driving. unless you meant total mileage, just rolled 100k. check out www.toyteclifts.com
and im not trying to be a jerk, but not everyone is nice.
Old May 18, 2007 | 02:27 PM
elripster's Avatar
Also, you might want to fill out your signature with pertinent information because, for example, whether you have an auto or stick will drastically affect your gear choice.
Frank
Old May 18, 2007 | 02:47 PM
tc's Avatar
tc
Why do you want to lift it?
How often do you 'wheel, and what level of trails?
Old May 18, 2007 | 06:50 PM
04 Rocko Taco's Avatar
Pretty much everything in this thread so far is right on point.
Most important what are your reasons for lifting, Im with Tcx, as this will DRASTICALLY affect what type of lifts you should be looking at...give us all the info we'll be glad to help you out with advice and opinions...
Oh, and your going to need a flame suit, or the search button.
Old May 19, 2007 | 06:12 AM
ovrrdrive's Avatar
36x13.5 r15 Iroks, 8.5" lift, 5.29's front and rear, and still about 17mpg...
Sometimes it's easier to just answer someone's question...
Old May 19, 2007 | 06:45 AM
ewong's Avatar
31x10.5
4.56 gears
1" of torsion bar with 300M torsions and downey dual hoop and dual Billys
2-3" of AOR longer (4"?) and shackles with remote res short can billys out back...
Old May 19, 2007 | 07:07 AM
4banginRunner's Avatar
1990 Toyota 4Runner 22RE/Auto
3" body lift
2" torsion bar crank
2" coil spacers
4.10 gears
31s = 17ish mpg
32s= 15 mpg
35s= 10-12 mpg
Old May 19, 2007 | 07:19 AM
norcalsvx's Avatar
i run BJ spacer (ball joint spacers from sdori) larger torsion bars 23.4mm (OME) with 33x15.50 muds and i get about 16mpg
Old May 19, 2007 | 07:29 AM
thook's Avatar
Here's a good thread to read on what you're asking:
https://www.yotatech.com/forums/show...nning+IFS+only
My 4rnr's are all stock suspension and gears. 30x9.5/15 on the '86 (19-20mpg) and 31x10.5/15 on the '92 (crap=approx. 14mpg). The '92 is having some issues right now, but it was getting around 17mpg before.
Lift? I'd only lift for tire clearance, and only if I actually needed to.
Old May 19, 2007 | 09:11 PM
TastySalmon's Avatar
I don't mean to hijack this thread but are people really getting below 20mpg when they run 32"+ tires? I run 32s on my '92 and I get 24mpg. I do have an intake and full exhaust but I don't think they would make up for the gain over you guys.
Old May 20, 2007 | 05:31 AM
ovrrdrive's Avatar
You're one hell of a mechanic then...
The window sticker on my truck when I bought it new said 17/19 on it.
Are you 2wd?
Old May 20, 2007 | 05:37 PM
elripster's Avatar
'94 4runner, 31X10.5's, BJ spacers, Coil spacers, 4.88's, auto, 15-17MPG. I can get 18MPG if I go the speed limit but I almost never do.
Frank
Old May 20, 2007 | 08:30 PM
Well I put 15 gallons in it right after I bought it and drove it over 350 miles, then put 15 more gallons in it when it was on empty. 350/15=23.3333
And I'm a 4x4 with a 2" lift.
Jcrawl94
10
Oct 24, 2015 04:34 PM
Sep 4, 2015 09:27 AM
Sr5crawler
Jul 31, 2015 12:32 PM
coffey50
Jul 28, 2015 10:55 AM
