Cheap Bump Stops?
Cheap Bump Stops?
Looking for some ideas for making cheap extended bump stops for my 82.
On my Jeep I used some longer bolts and washers to extend the rear bumps and some hockey pucks in the front coil buckets.
Any cheap ways like this for Toyotas?
im assuming sfa so i cant help you upfront, but in the rear couldnt you add a braket to the existing one and then use the ubolts to hold it down, what im saying isnt too clear...umm...i dont know if you recall, but there was a zuk mod to add coil springs to help lift the rear of leaf sprung pickups and 4runners...for some of them they used spacer brackets to bring the bump stop up...ill try and get a link
http://www.gearinstalls.com/dc.htm
scroll down to where they do the lifted truck, to make the coil work they add spacers to the bottom mounting point, well in your case you could just make the spacer, and attach the bumpstop to the top instead of the coil...
FS[GreatLakes]: 22RE performance and stock parts (pic heavy)
May 20, 2016 10:27 AM
punks_is_4x4
Aug 21, 2015 01:35 PM
icentropy
Jul 11, 2015 07:21 AM
