Cheap Bump Stops?
Old May 17, 2007 | 06:29 PM
Yota Tony's Avatar
Cheap Bump Stops?
Looking for some ideas for making cheap extended bump stops for my 82.
On my Jeep I used some longer bolts and washers to extend the rear bumps and some hockey pucks in the front coil buckets.
Any cheap ways like this for Toyotas?
Old May 17, 2007 | 06:30 PM
2WDoffroadx's Avatar
Would this create more up/down travel?
Old May 18, 2007 | 07:57 AM
Yota Tony's Avatar
No it will limit up travel so the springs don't go negative and break.
Old May 18, 2007 | 09:45 AM
91TPU's Avatar
im assuming sfa so i cant help you upfront, but in the rear couldnt you add a braket to the existing one and then use the ubolts to hold it down, what im saying isnt too clear...umm...i dont know if you recall, but there was a zuk mod to add coil springs to help lift the rear of leaf sprung pickups and 4runners...for some of them they used spacer brackets to bring the bump stop up...ill try and get a link
http://www.gearinstalls.com/dc.htm
scroll down to where they do the lifted truck, to make the coil work they add spacers to the bottom mounting point, well in your case you could just make the spacer, and attach the bumpstop to the top instead of the coil...
Old May 19, 2007 | 06:23 PM
dirtoyboy's Avatar
square tube..cut and weld
andrewtexas123
Jul 6, 2016 01:49 AM
Braparus
42
Jun 30, 2016 12:17 PM
May 20, 2016 10:27 AM
punks_is_4x4
Aug 21, 2015 01:35 PM
icentropy
Jul 11, 2015 07:21 AM
