1988 V6 truck, cannot move transfer case shifter???
I cannot shift my transfer case into 4 wheel drive. Even stranger, it looks like the shifter knob is very far to the right, maybe even further than when it is in the 4 high position. It worked great about a month ago. I had the truck towed because the clutch went out and I was thinking that somehow the transfer case was damaged during the tow or perhaps when the clutch was replaced?? Any ideas?
"pete f passed away quietly in his sleep on July 13, 2008
Did you try shifting it after going in gear . are you stuck in 2 HI. Mine is hard to get in 4 LO. If I find Neutral then i can get it in 4 LO.4 hi no problem.
raj
mct75
Aug 22, 2016 01:24 PM
shrek99352
Aug 31, 2015 04:16 AM
