1988 V6 truck, cannot move transfer case shifter???
Old Apr 16, 2007 | 04:41 PM
philb's Avatar
I cannot shift my transfer case into 4 wheel drive. Even stranger, it looks like the shifter knob is very far to the right, maybe even further than when it is in the 4 high position. It worked great about a month ago. I had the truck towed because the clutch went out and I was thinking that somehow the transfer case was damaged during the tow or perhaps when the clutch was replaced?? Any ideas?
Old Apr 16, 2007 | 04:51 PM
pete f's Avatar
"pete f passed away quietly in his sleep on July 13, 2008
Did you try shifting it after going in gear . are you stuck in 2 HI. Mine is hard to get in 4 LO. If I find Neutral then i can get it in 4 LO.4 hi no problem.
Old Apr 16, 2007 | 05:06 PM
rajin's Avatar
i think your shifter is not in the correct position....
raj
Old Apr 16, 2007 | 05:18 PM
DeathCougar's Avatar
when the clutch was replaced, they did not put the T-case shifter back in the correct position. Take it back to the shop, and have them correct the problem.
mct75
Aug 22, 2016 01:24 PM
andrewtexas123
Sep 23, 2015 07:48 PM
seab1209
Sep 3, 2015 05:41 PM
pplusent
Sep 2, 2015 11:56 PM
shrek99352
Aug 31, 2015 04:16 AM
