Tranny swap?
This'll give you an idea what should go behind what easily, transmissions & transfer cases.http://www.4x4wire.com/toyota/faq/parts/
These 2 have other good info.http://advanceadapters.com/toytruck.html
http://www.marks4wd.com/products/eng...lux-index.html
This one is just good Toyota transmission definitions.http://en.wikipedia.org/wiki/Categor..._transmissions
If your looking for a new transmission, transfer case or to rebuild then here.http://www.marlincrawler.com/htm/tra...ansmission.htm
Basically any pre-85 tranny will drop in and fit.
After 85, it'll bolt up, may require changes in the floor due to overall length.
Marlin builds great L51HD transmissions. Upgraded bearings, upgraded gearsets.
L series trannys will bolt right up. They are found on 83 and earlier trucks. Any 84-95 22re tranny (G or W series) will bolt up to the engine but they are longer then the early L trannys. So drive shaft and cross member work needs to be done if you use an 84-95 G or W series tranny. The pre84 L series trannies have weaker bearings and are more prone to failure then the later G and W series trannies. The L43 and 45 (4 speed) are supposedly weaker then the L50 and L52 (5 speed) trannies. Judging by the year of your truck you should have a L52 stock.
If you?re looking to put a G or W series in your truck, Budbuilt.com makes some killer cross members.
Iceman4193
Jul 15, 2015 04:48 PM
madxman21
Jul 9, 2015 10:26 AM
