tranny noises ?
Old Mar 4, 2007 | 03:34 PM
socsmm6's Avatar
tranny noises ?
I have an 88 model truck with a 5 speed, when you put it in 5th gear it makes a loud whining noise. what could it be and how do you fix it? the rest of the gears sound fine.
Old Mar 4, 2007 | 03:49 PM
jriebe's Avatar
Could be the synchro rings going out. does the whining happen in any other gears? I had the same problems in a zuk a few years back. The whine got bad in fifth and the shifter would vibrate a bit while in gear.
hope this helps.
Jon
Old Mar 4, 2007 | 04:14 PM
socsmm6's Avatar
tranny
the tranny sounds fine in 1st through 4th gear. it only makes the whining noise in 5th. we had to drive the truck about 200 miles to get home, didn't have any problems other than the noise.
Old Mar 4, 2007 | 04:21 PM
jriebe's Avatar
does the whine get louder when you take the load off of the tranny or is it constant?
would still put my money on the sunchro rings.
Jon
Old Mar 5, 2007 | 04:56 PM
socsmm6's Avatar
when you take the load off the noise quietens down, and gets louder the faster you go.
Old Mar 5, 2007 | 05:21 PM
ShortyzKustomz's Avatar
check the fluid yet?
Old Mar 5, 2007 | 05:42 PM
socsmm6's Avatar
just got it home. It will probably be the weekend before I can go over it good. where is the plug to check the fluid, driver or passenger side. will change all the fluids this weekend, tranny, transfer, and engine. also check the diff's. where can I find specs for the fluids online?
Old Mar 6, 2007 | 12:22 PM
ayoung101's Avatar
mine started the same way with just 5th gear. now, 2 years later, it does it in all gears except 4th (perhaps has something to do with 1:1 ratio?), the higher the gear, the louder the noise. you can really only hear it good in 3rd and 5th gear. all gears function properly still. i changed the tranny and transfer fluid back when it first happened. it didn't fix anything. but, like i said, 2 years later, still no problem with driving, and the noise hasn't seemed to get any worse in a long time.
Old Mar 6, 2007 | 01:52 PM
If fluids are good and it shifts good I'd drive it some more and see what you notice, me and my roomies yotas both whine a little, mines worse with 246,000 on the tranny
Bourbonblues
Dec 15, 2017 05:43 PM
YotaPagota
Sep 20, 2015 06:24 PM
Kreedy1
Sep 8, 2015 06:33 PM
zz_denis
Sep 6, 2015 03:43 PM
eggens
Sep 5, 2015 12:16 AM
