Why am I loosing oil?
Old Feb 25, 2007 | 05:39 PM
JEDI87's Avatar
I am loosing oil in my 22re. We put about a qt to a qt and 1/2 in between oil changes. It doesn't leak or smoke at all. The truck runs great and I have check the plugs and they are perfect. Any ideas? The engine has about 9,000 miles on it.
Old Feb 25, 2007 | 07:21 PM
DudeBud's Avatar
how long do you go before changes? ever motor burns a little oil
Old Feb 25, 2007 | 08:08 PM
JEDI87's Avatar
We go about 3,500 - 4,000 between oil changes.
Old Feb 26, 2007 | 02:16 AM
paxil4x4's Avatar
Drama Queen/Banned
That is not all that bad in my book
Old Feb 26, 2007 | 02:25 AM
Just Learning's Avatar
it may burn a little oil just when you shift a little puff and you may not even see it
Old Feb 26, 2007 | 02:42 AM
misterzee's Avatar
Probability of some rings not seating, if there are no external leaks. My 22re has 200k and does not use 1qt/3000 miles.
Old Feb 26, 2007 | 04:19 AM
keithguts's Avatar
I have the same problem. I have a 1995 runner with a compleat new top end, and I qt to 1and a half every 3000 miles. I also wish I knoew where it was going. Everything looks dry.
Old Feb 26, 2007 | 07:47 AM
bktaco's Avatar
i probably cant help you find the leak, but just out of curiosity, what is your fuel milage? my old 85 pickup was loosing a quart of oil every gas tank (i dont know where), but it was getting 32-34 mpg. so i never asked questions, just kept a case of cheap oil on hand and never needed to change it out except for filters.
Old Feb 26, 2007 | 08:48 AM
JEDI87's Avatar
It gets between 18- 22 mpg's depending on how I drive it. It doesn't leak at all.
Old Feb 27, 2007 | 04:00 PM
pruney81's Avatar
It's clearly burning it somewhere, the usage you are talking about is nothing. 1 quart per 1000 miles is considered normal use
Old Feb 28, 2007 | 09:43 AM
deserttoy84's Avatar
just look at your tail pipe on your exhuast. if it got lots of black crap built up its burning oil. usually when you dont burn oil it just has a light carbon film.
Old Feb 28, 2007 | 12:51 PM
JEDI87's Avatar
It just has a light layer of black carbon. I am thinking it's normal with the engine work that was done.
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
TJWilly
Jul 31, 2015 02:05 PM
Toyvana
Jul 29, 2015 10:47 PM
yourrealdad
Jul 29, 2015 11:08 AM
calderp
Jul 27, 2015 09:58 AM
