Wheel well engine shield
Old Feb 1, 2007 | 06:15 AM
4mydogs's Avatar
For lack of a better description . . .
that's what's gone missing from my 4Runner. I was washing it last weekend when I noticed it's gone. No idea when or why it came off. Without it
all this stuff is exposed. Should I be concerned? Had I better find one to replace it?
Old Feb 1, 2007 | 06:29 AM
Intrepid's Avatar
Mine has been gone for a while, I wouldn't personally worry about it, but obviously more crap will get flung into your engine compartment.
Old Feb 1, 2007 | 06:47 AM
mastacox's Avatar
Mine's been gone for a long time too. You'll just get a little more mud in there is all.
Old Feb 1, 2007 | 07:30 AM
4mydogs's Avatar
Well, if I can figure out what it's called and find one in a junk yard somewhere, I'll probably replace it. I just won't make it a priority.
Old Feb 1, 2007 | 07:55 AM
Stomis's Avatar
Replace that before you wind up with a clump of mud in your starter like I did...
Old Feb 1, 2007 | 08:01 AM
bob200587's Avatar
yea, starters don't like dirt much....
Old Feb 1, 2007 | 08:15 AM
4Crawler's Avatar
You can get one at a junkyard, or get some rubber sheeting at the local hardware store and make one or you can buy a set for all 4 wheels from Lift Lips (http://www.liftlips.com/).
Old Feb 1, 2007 | 09:50 AM
GV27's Avatar
Yeah, it's just a rubber sheet. Mine is ther, but doesn't want to stay in place very well.....
Old Feb 1, 2007 | 09:57 AM
deathrunner's Avatar
It sure makes it easier to change the filte ron my 22re with it gone. I stay away from mud anyway. Better cooling? who knows.
You should get some clear rubber/plastic like the stuff that hangs between the bucther and the rest of the grocery store. That way you could put colored LED's behind it. hahaha
Old Feb 1, 2007 | 10:00 AM
4Crawler's Avatar
On mine, I replaced the plastic push pins with riv-nuts crimped into the holes. Then I used brass screws in the threaded inserts. Makes for easy removal and they stay on very well.
Old Feb 1, 2007 | 11:06 AM
surf4runner's Avatar
(cant see pix-at work)
what side is it? i think i have the drivers side??? for an 87 p/u (also have the front valence )
Old Feb 1, 2007 | 11:10 AM
4mydogs's Avatar
It's the passenger side.
Old Feb 1, 2007 | 11:34 AM
ill have a look tonight and verify what i have, it still has the part# on it
Old Feb 1, 2007 | 11:39 AM
drguitarum2005's Avatar
From: Houston (home), Atlanta (school), Cincinnati (work)
ive been missing my driver's side one since i got the truck and havent noticed any ill effects
Old Feb 1, 2007 | 11:42 AM
seanz0rz's Avatar
Guest
i found mine hanging by a few clips the other day when i parked it for the week. ill fix that this coming weekend.
Old Feb 1, 2007 | 11:49 AM
CanTheWhales's Avatar
It's called a "mud skirt"... if you need the passenger and have a driver just put it on "inside out" it should fit pretty close... any piece of thick rubber would do the same thing though (you'd just have to cut it to size...
Old Feb 1, 2007 | 01:05 PM
Ric's Avatar
Ric
Banned - User requested
you can make your own, home depot sells this rubber carpet runner or carpet protector, not sure what they call it, but its only like $2 a foot, and cut it as long as you need it, thats what i used for the gap, works great.
Old Feb 1, 2007 | 01:12 PM
Ric's Avatar
Ric
found what i was looking for:
https://www.yotatech.com/forums/show...t=bodylift+gap
Old Feb 1, 2007 | 01:20 PM
GV27's Avatar
I replaced mine with zip-ties!
Jun 1, 2021 01:51 PM
Colington
Mar 8, 2020 09:51 AM
razorman8669
Jul 12, 2015 12:13 PM
87turboPA
Jul 12, 2015 07:49 AM
skoti89
Jul 6, 2015 07:45 PM
