My O/D light won't fash a code?
My O/D light won't flash a code?
Ok, first. Its a 87runner auto. A340H 22re 225k miles. Ive had it for about 3 years. Its been having shifting problems. Can't make up its mind where it wants to stay 2nd or 3rd its all over the place. so after A LOT of searching i thingk its the Tranns Solenoid. Only when I try to check the codes, the O/D light won't blink. The check engine light blinks a steady blingk but I can't get the O/D light to do anything. Ive used the papper clip trick connected the TE1 to the E1 and nothing. I have also made sure the O/d is on.
any advise??? anyone??? thanx
Oh. But what i read if there is no codes it should blink a steady blink????
Well thanx anyway. I just wanted to make sure before I order the Solenoid kit. The kit only comes with 3 solenoids and i was trying to make sure that i replace the right ones. thanx again.
The te1 and e1 will not make the transmission control unit flash a code, they are for the ECM for the motor/ignition/injection. You must ground the square plug behind the air filter. Then you switch the ignition to on, with overdrive on and the overdrive light will flash a code.
