My O/D light won't fash a code?
Old 01-18-2007, 06:22 PM
newjerseyredneck's Avatar
My O/D light won't flash a code?
Ok, first. Its a 87runner auto. A340H 22re 225k miles. Ive had it for about 3 years. Its been having shifting problems. Can't make up its mind where it wants to stay 2nd or 3rd its all over the place. so after A LOT of searching i thingk its the Tranns Solenoid. Only when I try to check the codes, the O/D light won't blink. The check engine light blinks a steady blingk but I can't get the O/D light to do anything. Ive used the papper clip trick connected the TE1 to the E1 and nothing. I have also made sure the O/d is on. any advise??? anyone??? thanx
Old 01-18-2007, 06:54 PM
misterzee's Avatar
steady blink of the check engine light, when the jumper is installed means "no codes" at least according to my FSM
Old 01-18-2007, 07:05 PM
MMA_Alex's Avatar
if its not flashing any codes it doesen't have any. on older trucks (pre odbII) you're going to have a hard time getting the computer to throw codes for minor issues
Old 01-19-2007, 05:33 AM
Oh. But what i read if there is no codes it should blink a steady blink????
Well thanx anyway. I just wanted to make sure before I order the Solenoid kit. The kit only comes with 3 solenoids and i was trying to make sure that i replace the right ones. thanx again.
Old 01-19-2007, 06:58 AM
Marc's Avatar
On my 91 the O/D light blinks when I short TE1 and E1.
Does the light work? Does it come on when you switch O/D off when driving?
Old 01-19-2007, 08:06 AM
4runnerx3's Avatar
The te1 and e1 will not make the transmission control unit flash a code, they are for the ECM for the motor/ignition/injection. You must ground the square plug behind the air filter. Then you switch the ignition to on, with overdrive on and the overdrive light will flash a code.
Old 01-20-2007, 06:19 AM
Marc, Yes the O/D light works fine at all times. I will try what 4runnerx3 said this morn. and get back to ya'll. thanks alot. bryan
Old 01-20-2007, 07:48 AM
OK! Found it! Flashing 61 speed sensor and 64 lockup solenoid. Now the question is Speed sensor???? do I need to replace or just clean or.... look for loose or severd wire???
smthwsn357
05-01-2024 07:28 AM
Liadrin
04-25-2022 02:54 PM
raptor510
02-17-2017 07:11 AM
Liadrin
09-01-2015 06:44 AM
jake_v
07-22-2015 03:17 PM
Quick Reply: My O/D light won't fash a code?
