Walbro pump for 94 pickup?
Old Jan 18, 2007 | 10:26 AM
jaredb3000's Avatar
Ive been looking for a couple hours online now, all Im finding is inlines for supras/mr2s, do any of these cross over, or does anyone know the appropriate model pump for 94 reg cab 4wd? muchos gracias
Old Jan 18, 2007 | 10:42 AM
mastacox's Avatar
Any particular reason you want a Walbro rather than an OEM replacement?
Old Jan 18, 2007 | 10:46 AM
jaredb3000's Avatar
I was thinking walbro over oem because of price, and going on the advice of a few people on yotatech.
Old Jan 18, 2007 | 10:54 AM
dcg9381's Avatar
I have a 255 Walbro pump.. I bought it as I was told that the stock fuel pump couldn't keep up with a turbo application. I haven't really pushed my motor, but to date it hasn't been necessary.
I bought it from:
http://www.autoperformanceengineerin...ml/fpapps.html
I'd buy their low end pump, it should flow more than enough volume, the & the price is right. Because this is an in-tank design with a "sock" for pickup, it's not rocket science to make it work. They do stock 4runner models.
The fuel pressure regulator should be able to bleed off any excess volume / pressure.
Old Jan 18, 2007 | 01:45 PM
mt_goat's Avatar
I've got the Walbro 190 (because of a supercharger) and it fit my in 93 ext-cab pretty good. I think I just bent the bracket a little bit to make it fit like the OEM did. I drove with it for a little while with my stock 3.0 and other than the noise I didn't notice a difference. The Walbros are a little noisey, they kind of sing to you, especially when the tank gets low. You might try URD for one: http://www.urdusa.com/
If you decide to go OEM, check the price here: https://www.1sttoyotaparts.com/tollfree.html
Or here:
http://www.trademotion.com/partlocat...?siteid=214074
Both have great service and prices.
Old Jan 18, 2007 | 01:47 PM
mt_goat's Avatar
What happen to your OEM pump? You don't hear about them going bad very often.
Old Jan 18, 2007 | 01:53 PM
mt_goat's Avatar
Yeah here's the one I put in:
http://www.urdusa.com/product_info.p...s_id=130000003
Oh I remember doing a little cutting on the steel tube now to make it fit in place. The instructions cover how to do it.
Old Jan 18, 2007 | 04:16 PM
jaredb3000's Avatar
Bought this truck recently, I know that it had a new gas tank installed, maybe that had something to do with it. Yota mechanic found the intermittent starting to be due to occasional low pressure from pump, and a solid whack with a rubber mallet on the tank would result in starting. (94 reg cab, 4wd, 4cyl ) many thanks again everyone who responded, doing this myself is going to save a pretty penny.
bigjstang
Jun 2, 2025 03:56 PM
Charecter1
Nov 6, 2023 10:08 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
redneck17
Jul 17, 2015 07:44 PM
Nickdigg
Jul 7, 2015 06:04 AM
