The Diff breather mod
Well i did the dreather mod for the diffs. Went to the local nissan dealer and got the breather things only like i think 5-6 bucks for the 2 and 8 feet of fule line and 2 fule filters all all adds up to im gona say 20 bones. Well eney way i started at the rear took the old breather out (witch i removed befor to see if it was causing the diff leak witch is a hole other story and it was) screwed the new one in ran the line to the tail light witch fit like a glove and now to the front took the old breather and ***SNAP*** F%$! half the damm threds are now stuck in my front diff. tryed the E-Z out dident work now im just contaminating my axles and gears with watter what should i do ive been tryin and tryin to get it out but i dosent want to buge. the peace is not visable it is threded into the diff . I was thinking if all else fails tack the new one on there? good idea?bad? help please
Andrew
Andrew
It's kind of hard to follow you here, but if I understand correctly I think I'd drill it out and install a timesert into it.
http://www.timesert.com/
Just drill the broken piece out, helicoil or use the insert from Overdrive's post and change the oil before you drive. Really wouldn't worry about a few microscopic flecks that you don't get in the change, the gear teeth wont notice imo.
You drill out the broken piece with a bit just larger than the original hole, tap the new hole, then thread in the insert and then you can screw in the new breather.
The insert will tell you which size bit to use, and depending on brand may even come with the right bit.
well you have threads from the old one in there, and you wanna just weld the new one on? what if the threads loosen and fall into your diff, that would cause some serious issues...as everyone else has said, drill, retap or use the inserts, and then put in the new breather, imo i think its crazy to leave those threads in there
Ok, it's already a PITA to just get to dif breather on the front IFS. How do you drill it out and tap it without pulling the axle????
I bought some black acrylic tubing from Home Depot and hose clamped it to the stock breathers (With the cap, seal and spring removed).
Didn't have to unscrew the dif breathers (tho I did anyways =p)
Incase anyone wants to avoid unscrewing them for fear of breaking them off! =) ..
TheBFA
Feb 15, 2020 06:55 AM
live4soccer7
May 11, 2016 06:52 PM
Odin
Sep 26, 2015 06:56 PM
