no head lights 1988 4 runner sealbeam has power
Old 03-16-2018, 05:46 PM
cruzdiaz's Avatar
to all three terminals no ground
Old 03-16-2018, 07:19 PM
Co_94_PU's Avatar
With the lamp plugged in this is exactly what you should have. They are ground side switched, you won't read zero volts or continuity to ground untill the switch is closed and there are no wire faults..
Poke around there should be a thread by Rad4runner on the light system..
In short check for voltage at the lamps, you did.. Check for ground at the switch, check for switch opening and closing circuit, check wires between cab and lamps.
Old 03-17-2018, 12:03 AM
RAD4Runner's Avatar
https://www.yotatech.com/forums/f116.../#post52379293
Old 03-17-2018, 05:38 AM
thefishguy77's Avatar
Tape headlights to the hood. Problem solved.
Old 03-17-2018, 10:08 AM
se7enine's Avatar
Old 03-18-2018, 07:58 AM
#Merica
Muxumus
03-15-2018 09:58 AM
jfadams
03-04-2018 08:14 PM
rs87a
14
02-27-2018 01:34 PM
Quick Reply: no head lights 1988 4 runner sealbeam has power
