no head lights 1988 4 runner sealbeam has power
Old Mar 16, 2018 | 05:46 PM
cruzdiaz's Avatar
to all three terminals no ground
Old Mar 16, 2018 | 07:19 PM
Co_94_PU's Avatar
With the lamp plugged in this is exactly what you should have. They are ground side switched, you won't read zero volts or continuity to ground untill the switch is closed and there are no wire faults..
Poke around there should be a thread by Rad4runner on the light system..
In short check for voltage at the lamps, you did.. Check for ground at the switch, check for switch opening and closing circuit, check wires between cab and lamps.
Old Mar 17, 2018 | 12:03 AM
RAD4Runner's Avatar
https://www.yotatech.com/forums/f116.../#post52379293
Old Mar 17, 2018 | 05:38 AM
thefishguy77's Avatar
Tape headlights to the hood. Problem solved.
Old Mar 17, 2018 | 10:08 AM
se7enine's Avatar
Old Mar 18, 2018 | 07:58 AM
#Merica
Muxumus
Mar 15, 2018 09:58 AM
jfadams
Mar 4, 2018 08:14 PM
rs87a
14
Feb 27, 2018 01:34 PM
