1985 4runner not getting fuel after jumping wrong terminals
So I think I screwed something up by jumping the wrong terminals. In my defense, there doesn't seem to be much detail on the exact jumpers to jump for early 22REs. in Any case, I meant to jump TE1 and E1 and think I jumped something related to the fuel pump because now it won't start. I was going to check the timing but couldn't remember which round plug had the Te1 and E1 terminals. I chose the large plug and shoved the paperclip in the terminals I *thought* were correct (red dots in the attached image). Of course I did while it was running and immediately my 4runner died and when I try to restart it, it just cranks but does not get fuel. I tried resetting the battery...checking fuses...no luck. Did I short out my fuel pump or something? As an aside, I think the correct terminals I should have used for TE1 and E1 are indicated in green. Can someone confirm?
Fixed the starting issue....I forgot about the fuses above the kick panel. Ended up being the 15a fuse. But, am I correct in assuming TE1 and E1 are indicated as green dots in the image?
