RAM speed
Old Aug 9, 2004 | 03:57 PM
yota_boy's Avatar
RAM speed
hey im buying some ram probably some 512 ddr 184 pin but I forgot how to check what speed of ram you need to get can you gusy remind me?
Old Aug 9, 2004 | 04:20 PM
midiwall's Avatar
There may be an automated way of doing it, but if not, what motherboard are you planning to plug it into?
Old Aug 9, 2004 | 05:08 PM
yota_boy's Avatar
well its a pentium 4 processor with 2.4 ghz processor and I have 480 mb of ram allready, not exactly sure on the motherboard
Old Aug 9, 2004 | 06:48 PM
redfox435cat's Avatar
a couple ways. go to your BIOS turn off your computer and enter the setup mode either hold f2 f12 shift f2 or esc or howevery your mother board it set up anf look for the ram amount and speed. also try
assesories - system tools - system information and look for RAM it usually only gives the amount.
the best way if you don't have the build sheet or build it yourself is just open the case and look at the label on the RAM in the system
Old Aug 10, 2004 | 01:28 AM
Corey's Avatar
Co-Founder/Administrator
You are running the same chip I am if you have the 800 FBS one (C chip).
More than likely you have PC3200 RAM, which must be installed in pairs to take advantage of the 800 FBS.
It will help if we know what mobo you have too.
If you don't have the C chip, then your 2.4 is the 533 MHz one, and not the 800 FBS one.
Also you can download the free version of Si Soft Sandra from here.
http://www.sisoftware.net/
It will tell you lots of stuff about your PC including the RAM speed.
Old Aug 10, 2004 | 04:35 AM
MTL_4runner's Avatar
I use to use sisoft sandra until I used PC Wizard 2004......works even better!
Download it here:
http://www.cpuid.com/download/pcw2004_v163.exe
Then install and run the program, click on "physical memory" and voila, all your RAM specs!
It will tell you how many slots you have, how much in each and what type it is.
Old Aug 10, 2004 | 09:23 AM
midiwall's Avatar
Download it here:
Very nice Jamie! Thank you!
Old Aug 10, 2004 | 10:13 AM
No probs bud, thank Jim (amusement).....he put me onto it first.
Old Aug 10, 2004 | 02:39 PM
Corey's Avatar
Cool, just DL'd the program, and it does indeed show me that I run PC3200 RAM.
I like it better than Sandra.
87blyota
Sep 3, 2015 03:35 AM
ATVTRAILRIDER
Aug 19, 2015 06:44 PM
izzmee
Aug 17, 2015 10:20 AM
priest16
15
Aug 6, 2015 07:43 AM
wilbertd
Jul 6, 2015 07:39 AM
