PC tips
Co-Founder/Administrator
PC tips
Share your PC tips here in this thread.
Whether hardware or software related.
We have a lot of people on this forum in the software and hardware side of business, and I am sure a lot of us appreciate tips on resolving PC headaches.
I build my own computers, so I have quite an extensive knowledge on problem solving glitches that may pop up.
And before the Mac enthusiasts jump in and say "what headaches" I beat ya to the punch
I am sure Mac owners on here will also appreciate any tips, and Mac tips are encouraged in this thread too.
Here is my first one from another post recently.
Updating video card drivers:
Whenever updating either NVIDIA or ATI's Catalyst drivers, you need to wipe the old ones off your hard drive before installing new ones.
I update my Catalyst ones every time ATI releases new ones, which is about every 5 weeks.
Here is the proper way.
1. Go to the add/remove area in the Control Panel, and select the drivers and uninstall.
Then remove the cat control panel software.
2. Go to Program Files in the Explorer and delete the ATI folder.
Same info for NVIDIA drivers too.
3. Reboot the PC.
Hit cancel when the "Found new hardware" message appears.
4. Run the program Nasty File Remover and let it search for anything ATI or NVIDIA.
By default it is setup to save the files as a batch file.
Do not do that, but drop down the drop list and select delete instead.
5. Reboot the PC after using NFR, and then hit cancel once again when the "Found new hardware" message appears.
6. Go to your drivers you downloaded from either ATI or from NVIDIA, and execute them.
If using an ATI card, you may run into trouble getting the Catalyst ones with the Control Center.
Go for the smaller download of the Control Panels ones.
I have seen the bigger package fubar a few PCs, and the smaller file is much more stable.
Always do the above when updating your vid or sound card drivers.
Simply executing the new drivers over the old ones is not a good idea.
3. Reboot the PC.
How to format
A very good article with many steps and links on how to format your PC.
http://www.cyberwalker.net/faqs/rein...nxp/index.html
To show ALL devices in Device Manager in Windows 2000/XP/2003, do the following:
1. Right click My Computer, select Properties
2. Click the Advanced tab
3. Press the Environment variables button at the bottom
4. Select any item in the System variables section at the bottom
5. Press the New button and do the following:
In the Variable name field, type: DEVMGR_SHOW_NONPRESENT_DEVICES
In the Variable value field, type: 1
6. Click Ok a few times.
7. Go to Device Manager and click View\Show hidden devices
You will notice a few new categories and you can also see all the hardware that was once installed in your system and that still may have entries hanging around in the registry. They will be "greyed out" and fainter in appearance. We call them "Ghosts". This is a useful switch when troubleshooting hardware errors.
Hope you found this interesting.
G
G
To vastly improve the performance and stability on Windows 98/98SE/ME if you are still using one of those operating systems, do the following.
This is called the "System Performance Hack"
1. Right-click My Computer.
2. Click the Device Manager Tab.
3. Open the Disk Drives Category and check the properties pages of all the HDD's. Make sure that the HDD's are using DMA. Put a check in the DMA checkbox if it's empty. It's on the Settings tab. Okay your way out.
4. Do the same for the CDROM/DVD/CDRW drives.
5. Ignore the warnings that enabling DMA will cause major flooding and erectile dysfunction.
5. Open the System Devices Category and open the Direct Memory Access Controller properties. Set the DMA Buffer size to 64. That's the largest value supported.
6. Ok your way out of all the dialogs. Cancel ALL prompts to reboot.
7. Go to the Performance tab.
8. Click the File System button.
9. Set the typical role to Network Server.
10. Make sure Read Ahead Optimization is set to Full. Ok your way out.
11. Click the Virtual Memory button.
12. Select "Let me choose" and set the Minimum size to a value equal to 1.5 x Physical RAM. (See below for relative values.) Leave the Maximum value alone. If they have more than one HDD, put the Swapfile on the second disk.
13. Ok your way out.
14. Ignore the warning about Windows eating your first born...
16. Close System Properties. Cancel all prompts to reboot.
17. Start\Run\msconfig
18. Click the System.ini tab.
19. Click the [386Enh] folder, not the + sign next to it.
20. Click the New button.
21. Type: ConservativeSwapfileUsage=1
22. Press [Enter]
It will look like this:
[386Enh]
23. Click "Ok"
24. Reboot.
25. Done
Swapfile Sizes:
64MB RAM = 96 Swapfile Size
128MB RAM = 192 Swapfile Size
256MB RAM = 384 Swapfile Size
384MB RAM = 512 Swapfile Size
512MB RAM = 768 Swapfile Size
768MB RAM = 1024 Swapfile Size
1024MB RAM = 1024 Swapfile Size
Windows 98/ME does not support more than 1GB of RAM nor can it access more than 2GB of Memory Space, which is why the last entry is equal to the RAM value. Any larger values are simply ignored.
We used to do this all the time when I was a Dell Support Technician and I also trained all my new and existing Techs to do this. This resolved about 90% of our support calls as out of the box, Windows 9x doesn't use memory or system resources very efficiently.
These changes makes a HUGE difference in the way Windows handles memory, the swapfile and greatly accelerates the opening of programs, allows you to actually multitask and run modern 3D games without pauses, hitches and various other problems as long as you have enough memory to hold all the programs and not have to use the swapfile.
By default, Windows will use the swapfile, even if you have plenty of RAM to store the data that's in use and that causes slow downs and instability. Plus, you spend a lot of time "waiting" for your computer while it moves data to and from the harddrive while it's opening or switching programs.
Peace.
G
22. Press [Enter]
[386Enh]
23. Click "Ok"
24. Reboot.
25. Done
Swapfile Sizes:
Peace.
G
Here are a couple of tips for you wireless users to make your connection a "little" more secure....
1. Change the SSID of your access point.
2. Turn off SSID broadcasting
3. Enable some form of WEP. I would recommend at least 128bit with a couple of keys at the least.
4. Turn on MAC filtering. By enabling that, it will only let what MAC's you specify on the access point.
5. Turn off DHCP. I always have used statics on my wireless networks.
6. If needed you can always crank down the wattage the access point pumps out so that you'll only be able to pick it up in the room you are in.
Greetings,
In line with Data's post, Limit the amount of PC's allowed on your network to the amount of PC's you own. This way if you allow three static addresses and a fourth tries to get on, it won 't work.
Also, here is a quick to the point security test that was posted on CNN.
1. My computer has anti-virus software installed.
True
False
I'm not sure
Explanation: If you answered false, you're ignoring one of the most basic ways to protect your computer. If you're not sure you have anti-virus software, search your computer for programs from Norton AntiVirus or McAfee.
2. My computer has a firewall program installed.
True
False
I'm not sure
Explanation: If you answered False, put down what you're doing and go get one installed right now. You can get free firewall software for basic protection or pay for better, more complex firewall programs. (See more.)
3.3. I always read the "terms of agreement" before I download free software.
True
False
Most of the time, but definitely not all of the time.
Explanation: Reading terms of agreement is the best way to make sure you're not agreeing to let a third party install spyware on your system. Because you've agreed to it, a firewall can't keep it out. Search for words like "third-party" and names of companies you don't recognize.
4. I always click "yes" when I'm prompted by my software vendors (like Microsoft) to update my security.
True
False
I'm not sure
Explanation: New viruses are written every day, so the longer you go between updates, the greater the number of viruses your out-of-date protections might let in. Check with your vendors, like Microsoft Critical Updates, to see how your system is doing.
5. I only open e-mail attachments if I am expecting them.
True
False
I'm not sure
1. Explanation: Never open attachments you aren't expecting -- even ones with return addresses from friends. Many viruses go right for the e-mail addressbook to make it seem as though the victim is sending legitimate mail.
6. My e-mail is configured to allow for only text-only messages.
True
False
I'm not sure
Explanation: The majority of e-mail viruses use html and otherwise enhanced e-mail to gain access to your system. Text-only messages (so retro!) can't launch themselves automatically, and are one more solid defense between you and a virus.
7. I always turn my computer off when I'm not using it because I have continuous Internet access.
True
False
True some of the time, but not always
0 pts Doesn't apply to me
1. Explanation: This certainly will deny any outsiders access to your system. It's not necessary, however, if you have a good firewall. It also depends on your usage. Set the energy saver preferences properly and there's no need to shutdown/reboot every night
8. I saved my passwords in a file on my hard drive.
True
False
Explanation: If someone does get into your system, you're allowing them access that they don't even have to work for. Keep passwords offline -- perhaps on a piece of paper -- or better yet, in your head.
True
False
I'm not sure
True
False
I'm not sure
True
False
True
False
I'm not sure
True
False
I'm not sure
True
False
I'm not sure
True
False
True
False
If you don't know where to get a good antivirus program from and don't want to pay for one:
AVG Free Edition
Also, 2 good free firewall programs:
ZoneAlarm Firewall
Sygate Personal Firewall
If you want to pony up the dough for a program, I recommend Symantec Corporate Antivirus and Firewall, NOT "Norton". The Symantec Corporate stuff has very little overhead, taking up a very small amount of computer resources, as opposed to the Norton badged stuff, which can cause a noticable lack of speed. You can find their stuff at www.symantec.com.
The free stuff is not any better or worse than the stuff you pay for. You just get more customizability and more features with the paid for stuff. I recommend trying the free stuff out first and if you're happy, use it. I used Sygate and AVG for a long time before getting a copy of Symantec Corporate, and I had absolutely no problems.
AVG Free Edition
ZoneAlarm Firewall
AVG Free Edition
ZoneAlarm Firewall
AVG Free Edition
ZoneAlarm Firewall
Spyware scams
Do not fall victim to those pop up ads saying you may have spyware on your computer.
They scam you into scanning your PC for you, and often put on spyware themselves.
This article was linked from Spybot's home page.
http://www.pcworld.com/news/article/...62,pg,1,00.asp
I run Spybot Search & Destroy because it is good and free, and I also run a paid version of Spysweeper which is very good.
Also I have Ad-Aware another free one, but I prefer the first two mentioned ones over it.
I get my new definition files every Thursday, and scan that night.
Once a week scanning is good, or more often, and I never have spyware on any of my PCs.
If you do alot of web surfing esp. if you look alot on hacker sites or porno (hate to say it), I'd recommend scanning for trojans every other day, schedule it to scan while your asleep or at work for your convinence. Also a good anti-trojan software will work better then normal anti-virus software, when it comes to looking for trojan's picked up by simply surfing the web
Does your PC crash for no reason?
I formatted a few months back, and shortly afterwards the PC would crash for no reason in a few of my games:
Unreal Tournament 2004 (but not the older UT)
Starwars Battlefront
And yesterday the new Half Life 2.
Very frustrating, and also the PC would reboot sometimes while surfing the 'Net.
Not normal.
I was suspecting my power supply, as it is only a 300 watt one, and a gaming rig should have between 400 and 550 watts, especially with the extra lights and fans I have in my case.
Member Drew came over yesterday, and we DL'd a program called MemTest86.
His new AMD super gaming rig he just built was crashing in games too, and not normal, as we both always run the latest updates for our cards, BIOS, and game patches.
He found out about a program that will test your memory that is called MemTest86.
http://www.memtest86.com/
You exeecute the program, and it makes a boot floppy for you that you test one RAM module at a time with it.
He had found that one of his 512 sticks was faulty, and replaced both and his PC stopped crashing entirely.
We ran the test on mine yesterday, and both of my sticks were good.
Still I thought of one more reason, and Andy thought it might be the same thing too.
When I built the PC, I put in a 56 speed A-Open CD ROM drive.
Afterwards I put in a Sony DVD/CD burner, and set it up as the slave to the other one.
Shortly within a month the 56x CD ROM was not reading discs all the time, and eventually quit altogether, so I have just been using the burner to read discs with.
We pulled out the 56x one, and then made my burner the master drive on the secondary channel.
Guess what, my youngest son played Half Life for about an hour last night and no crashing.
The games before were crashing after about 5 to 10 minutes into them.
So it was the 56x CD ROM that was causing all of this crashing, even though I was not using it.
So hopefully if anyone else has a bad CD ROM unit in their PC and you are crashing once in awhile hopefully this tip will be of value to you.
Still going to replace my power supply down the road though, but it is nice now that the PC no longer crashes.
Who would have thought it could be a dead CD ROM drive that was causing this?
The CD ROM unit though always showed up in MY Computer, although you could not get it to read a disc.
Not normal.
Short and sweet.
Download Mozilla. Install norton Antivirus.
For those that use ATI Cards in laptops, download the Omega drivers. http://www.omegadrivers.net/
Since ATI doesnt release mobility drivers, your stuck using the aftermarkets. But I am completely happy with the current set.
Below are a couple of links with some good info. Overall security-forums.com is a pretty good security site.
How to create a secure password
http://www.security-forums.com/forum...ic.php?t=18842
Beginners Guides: Firewalls and Internet Security
http://www.security-forums.com/forum...pic.php?t=7791
Places that viruses and trojans hide on start up
http://www.security-forums.com/forum...pic.php?t=3752
Wireless Security & Hacking
http://www.security-forums.com/forum...pic.php?t=1139
Home Network Security
http://www.security-forums.com/forum...opic.php?t=839
This link was in another thread here.
http://www.anandtech.com/
Good place for tech info via forums, and also great tech articles on gear with reviews such as this transparent case.
How much wattage do you need?
Here is a cool site to see how big of a power supply you should be running.
http://www.jscustompcs.com/power_supply/
