Need to delete windows
Old Jul 30, 2005 | 05:25 AM
Gangus2006's Avatar
I was trying to set up a RAID1 array in a new system, and I stupidly installed windows first. I now need to get rid of windows. How do I do that. I tried formatting drive c but windows wont let me...
Old Jul 30, 2005 | 05:36 AM
callmej75's Avatar
I have a disk made by Vcom called systemsuite that has a disk eraser on it.
Old Jul 30, 2005 | 05:58 AM
Churnd's Avatar
Any program that'll boot from a floppy will work, even FDISK. Look around Maxtor's website for a few programs they have for that.
Old Aug 1, 2005 | 05:24 PM
ldivinag's Avatar
windows wont allow you to format it's own boot volume.
Old Aug 1, 2005 | 08:21 PM
MeinPappa's Avatar
If you've got the windows disk lying around, just boot from it. With XP, if it finds an OS already on the primary HD partition, it should give you the option of dropping out to a command shell (and formatting it) or formatting it and messing with the partition table (by way of installing a new OS). Either option should work for your purposes.
Old Aug 1, 2005 | 09:37 PM
ldivinag's Avatar
on my win xp pro CDs, when you boot from it and find a bootable windows volume, you can wipe it out by doing a reformat.
now this is in the process of putting a fresh layer of windows.
but if all you want is to wipe out windows, then do this method.
only time i get a command prompt is the REPAIR option and even that, i dont think the FORMAT command is available. after all, you are trying to REPAIR your faulty windows installation...
Old Aug 1, 2005 | 09:42 PM
ldivinag's Avatar
wait... i would NOT raid the windows volume.
i'd raid the data volumes...
EDIT: wait... raid 1 is a mirror of a volume.
you can turn on and off mirror of a volume in windows on the fly. raid 1 is a 2 HD configuration where the first drive is the primary/boot volume and the 2nd drive is an exact copy of it.
we would do this when we are doing something to our webserver. first make sure 2nd drive has a good copy of drive one. break the mirror and then add the hardware or software. make sure machine works as normal. then reconnect the mirror. this takes an hour or so though...
Old Aug 2, 2005 | 01:05 PM
jscarrozzo's Avatar
Do a search on google for "KillDisk". You can also probably find it on download.com. I use it at work all the time.
RDubya
Feb 10, 2017 04:46 PM
A2theK
Oct 14, 2015 07:10 AM
PNW94Runner
Sep 29, 2015 02:55 PM
punks_is_4x4
Sep 19, 2015 05:52 AM
