Home Network
Old Mar 28, 2006 | 01:10 PM
  #41
DavidA's Avatar
This may sound stupid...but in XP unless you SHARE something then neither computer will show up in the workgroup. XP assumes that unless you want to share something there is no reason to show up on the list. Just an FYI.
Yes you can ping it, etc. But it will not show up as a network resource until you share a drive, folder, printer, etc.
Sorry if you already covered this, but just wanted to make sure.
Also, there is a common issue with Windows XP, the Winsock proxy client sometimes get corrupted. I see this often in my work. We use this WinSock XP fix.
http://www.snapfiles.com/get/winsockxpfix.html
"WinSock XP Fix offers a last resort if your Internet connectivity has been corrupted due to invalid or removed registry entries. It can often cure the problem of lost connections after the removal of Adware components or improper uninstall of firewall applications or other tools that modify the XP network and Winsock settings."
Just a few hints...Hope it works.
Old Mar 28, 2006 | 01:31 PM
  #42
midiwall's Avatar
True that, but remember that Justin has a core issue that the machine names won't resolve, period. And, XP will show you the difference between a machine with shares, a machine without shares, and a machine that it can't find:
Code:
c:\home>net view \\mxp-2
Shared resources at \\mxp-2
Share name  Type  Used as  Comment
C_ROOT      Disk
D_ROOT      Disk
Code:
There are no entries in the list.
Code:
c:\home>net view \\mxp-xxx
System error 53 has occurred.
The network path was not found.
Worth a shot!
Old Mar 28, 2006 | 05:11 PM
  #43
justinh's Avatar
Both computers have the same IP address!
After reading up on winsock I don't think it will fix my issue, it is for restoring internet connections that were damaged due to adware. I haven't had any problems with my internet connections.
I have the feeling that we are totally overthinking all of this.
Old Mar 28, 2006 | 06:06 PM
  #44
Churnd's Avatar
Ok, is your router set to DHCP?
Old Mar 28, 2006 | 07:09 PM
  #45
justinh's Avatar
yes? i think...
is there a way for me to show my print screen
Local DHCP Server: <---is marked enabled
Old Mar 29, 2006 | 05:12 AM
  #46
Churnd's Avatar
Ah.... weird. You probably should reset your router:
  • Disable both connections each computer by right clicking on My Network Places | Properties | Right click on network connection | Disable.
  • Unplug the power connection to the router.
  • Wait about 2 mins (some take as long as 10 to be fully clear).
  • Plug it back in.
  • Re-enable one connection at a time.
  • Verify the IP addresses.
As you can see on the bottom of the page here, this is a pretty common problem... especially with wireless and home networking.
Old Mar 29, 2006 | 06:30 AM
  #47
midiwall's Avatar
Wait Chris.. I think Justin's referring to the WAN IP address - the result of him going to whatsmyip on both machines.
Okay, but did you try it?
Old Mar 29, 2006 | 06:33 AM
  #48
Churnd's Avatar
Doi... didn't think of that. I assumed it was the router's IP (192.168.xxx.xxx).
I agree. Winsock is useful for more than cleaning spyware.
Old Mar 30, 2006 | 12:14 PM
  #49
justinh's Avatar
well...i decided that last night i wasn't going to work on it since i got home so late. So, i sat down checked my e-mai, checked yotatech, was getting ready to go to bed and checked it real quick and was able to access the shared folders on the laptop from my desktop. So, who knows, it just started working...
Old Mar 30, 2006 | 12:31 PM
  #50
jdickerson's Avatar
??? Did you test printing to the share from the laptop?
Old Mar 30, 2006 | 01:23 PM
  #51
justinh's Avatar
i haven't yet, I was literally on my way to bed when I found out it was working and the laptop was shutdown. I don't expect the printing to work without some more fanagaling.
smilen724
13
Nov 8, 2015 04:11 PM
Chicken12
Oct 14, 2015 03:54 PM
the_supernerd
Oct 1, 2015 09:20 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
Toys4parts
Sep 26, 2015 01:56 PM
