flash drive help
flash drive help
I was wondering what brand of flash drive is good. i need it for one of my classes that uses MACs. It has to be 256MB. also, if i use it on a mac, will i be able to use it on a regular pc? i am going to be using these programs adobe photoshop, adobe illustrator, InDesign, and QuarkXPress. thanks for your help
Matt
Matt
I'm not 100% sure, but I think it should. Files are files, no matter what OS they're created on. If they're created with photoshop, they can be opened with photoshop... no matter what OS photoshop is on. I know this is true in some (if not all) cases because I've seen a PowerPoint presentation created on a Mac open on a Windows machine.
As for the flash drive, I'd go with SanDisk. Try www.newegg.com or www.buy.com and see what you can find. I have a SanDisk Cruzer Titanium 512mb thumb drive (the USB connector slides in and out), with the thumb drive part being a pretty cool feature. It glows blue when in the port and flashes when being read or written to. I love it and couldn't do without it now.
The only thing I can see being a problem is the way the drive is formatted. I'm sure Mac uses a different format than Windows, so that might be an issue.
Actually, they come formatted with the FAT (File Allocation Table) file format. DO NOT reformat the thing. If you format it for NTFS (a much better file system) it will be useless the minute you remove it from the machine.
I own 4 of these type drives. All of them came preformatted and ready to use. Just stick it in the USB port and the computer should "see" it right away. When you want to remove it from the computer it is a good idea to click on the little icon in your system tray (by the clock on the bottom right) that appeared when you put it in the USB port and "stop" the device. That helps make sure that any files that are open on the USB device are saved and closed prior to removal.
-Sherpa
-Sherpa
jasonty
41
Dec 23, 2018 01:00 PM
Poncho0206
Jul 10, 2015 06:21 PM
Jnkml
Jul 6, 2015 01:20 PM
