"drive is in use by another application" error
Old Sep 8, 2004 | 04:09 AM
jacksonpt's Avatar
Senior Member
OK... more DVDShrink/DVD Drive questions...
After some help from the board, I got my DVDRom to read DVDs again (apparently I needed to clean the lens). I use DVDShrink to rip and burn DVDs - ok, technically I use Nero to burn, but it's "embedded" in DVDShrink, so...
Anyways... lately I've been getting an error when the burn phase begins that my burner is in use by another application. It gives me this error all the time - even if I start my computer and try to backup a movie (i.e. when nothing should be using the drive).
Does this sound like a software issue? Hardware conflict (IRQ perhaps)? Something else?
Any tips would be great - I'm way past frustrated.
Old Sep 8, 2004 | 05:24 AM
Churnd's Avatar
Sounds like a conflict with another application. Do you have any other burning software on your machine, DVD or otherwise?
Old Sep 8, 2004 | 05:26 AM
jacksonpt's Avatar
Senior Member
I've got EZ CD Creator (Roxio), but that was installed long before DVD Shrink and never caused any problem until now. Could DVD playback software be an issue? Perhaps I'll reinstall Nero/DVD Shrink just to be on the safe side?
Old Sep 8, 2004 | 05:37 AM
Churnd's Avatar
Try that, and if that doesn't work, try re-installing the drive.
Is there anything else you changed recently? Such as, did you update to Windows Media Player 10 or download some other movie viewing software?
Old Sep 8, 2004 | 06:05 AM
jacksonpt's Avatar
Senior Member
Try what... uninstalling roxio, or reinstalling nero/dvdshrink?
Nope - the computer has sat (not even plugged in) for about 2 months. When I hooked it back up, I started having problems. First it was problems reading DVDs (which I fixed, then burned a DVD without any problems), now this. I don't even have internet access at home, so updates aren't a possibilty. I haven't installed anything in a while, so I can't see how that would be an issue.
FWIW... when I started having the problem, I did uninstall a few DVD playback utilities.
Old Sep 8, 2004 | 10:37 AM
Churnd's Avatar
Sorry, I meant first try re-installing dvdshrink. If that doesn't work, try re-installing the drive itself. If you have XP, it's a simple matter of uninstalling the driver and letting XP re-install it. If you know what kind of drive you have, you might wanna search around for a driver on the "net while you're still at work, and copy it to a disk to take home or something. It's also a possibility you might just need an updated driver.
If none of this works, try un-installing roxio, and see if it'll burn that way. Just gotta go through all the steps... basic elimination.
Old Sep 8, 2004 | 10:41 AM
jacksonpt's Avatar
Senior Member
Thanks for the tips... I'll try them tonight.
Old Sep 9, 2004 | 04:09 AM
jacksonpt's Avatar
Senior Member
I reinstalled DVDShrink - no dice. So I just cut to the chase... uninstalled Roxio and both drives, windows reinstalled the drives and everything seems to be working fine again. Burned 2 DVDs last night - thanks.
Old Sep 9, 2004 | 04:49 AM
Corey's Avatar
Co-Founder/Administrator
Roxio is Nero's competitor, and I bet there is an ap running by Roxio in the background that monitors your drive.
I would uninstall Roxio completely, then see if that clears it up.
Oooops, I see you did just that, and it worked.
I did not see your last post here, trying to rush and get off here to leave for work soon.
But yeah, Roxio was using a resourse that messed with Nero.
Old Sep 9, 2004 | 04:55 AM
jacksonpt's Avatar
Senior Member
I know that they are the big 2... but it seems odd that there was never a problem between the two until now. Oh well... all is good.
Old Sep 9, 2004 | 11:37 AM
WT's Avatar
WT
I have roxio on one of my 98 machines and remember it would on occasion tun on and off (wehn I would reboot kinda random) what it calls as wright on demand and when that was running it would monitor the CDR all the time and my guess is that might of been what was causing Nero a small problem.
Old Sep 9, 2004 | 11:53 AM
jacksonpt's Avatar
Senior Member
hrm... interseting - thanks for the tip. I hate software that thinks for itself.
Old Sep 13, 2004 | 06:19 PM
redfox435cat's Avatar
whoops he did that
Roxio is causing your problem. unistall roxio. if you really don't want to uninstall roxio.
one is roxio loaded in the background?
if: it is remove it from the boot process.
go to
START RUN type in (msconfig)
under the startup tap look for the roxio aplication and uncheck it. uncheck other unnessary programs and it will improve your system performance. make sure spooler, svchost, video and sound drivers antivirus are left alone
reboot the system you'll get a (your running in dignostic mode) or something of the like. check the box saying don't show me again
if your still getting the error then unistall roxio.
Old Sep 13, 2004 | 07:31 PM
CynicX's Avatar
Roxio is crap....i have yet to find it useful in any way....nero is 1000x more powerful....
when i bought my dvd burner it came with Roxio DVD burning software....but Roxio wont let you back up any commercial DVD...ex. movies, tv shows, anything at all basically...what is the use of that crap....
uninstall it and stick with nero....
jasonty
41
Dec 23, 2018 01:00 PM
Tykiller1994
Aug 10, 2015 07:49 PM
kyletbert
Jul 17, 2015 11:39 AM
Poncho0206
Jul 10, 2015 06:21 PM
Jnkml
Jul 6, 2015 01:20 PM
