GPS & Communication Discussions here pertain to the use and troubleshooting of GPS, CB radio, and amateur radio
CB Radio Tuning
Old Sep 9, 2007 | 12:35 AM
DAS_GTI's Avatar
CB Radio Tuning
So I've heard from many sources how important it is to tune your CB setup once it is installed before using it heavily... I am having the hardest time finding ANYONE who knows what that is... I'm in Simi Valley, CA and I've called everyone here as well as the San Fernando Valley with "radio" in their company name... no one can recommend or knows where I can get my CB setup tuned.
I know it's simple but I would really just prefer to have it done professionally for like $20 bucks so I don't have to worry about it. Anyone have any suggestions?
Old Sep 9, 2007 | 12:39 AM
rocket's Avatar
Depends what you have...? are you asking about your antenna or the CB itself?
Old Sep 9, 2007 | 12:45 AM
DAS_GTI's Avatar
Don't you need to have the Antenna/CB radio unit tuned together after install?
Old Sep 9, 2007 | 12:58 AM
KevinInSac's Avatar
Dude, buy a SWR meter off ebay for like 15$ and do it yourself. My firestik just requires turning a screw at the top of the antenna. Only downside is the meter plugs directly in line between your cable and the CB, so you'll have to pull it.
Oh, and try calling a truck stop. They'll know wat you're talking about.
Old Sep 9, 2007 | 07:55 AM
Merlin's Avatar
if you mean tuning the antenna, then the above poster is correct. all you need is a swr meter and a short patch cable.
radio -> swr meter -> antenna.
follow the directions that came w/ the swr meter. if you have a firestik or skip shooter, you're in luck - you have an adjustable tip (screw for firestik, nail for skipshooter).
if you have a whip with a loading coil (usually bottom load), sometimes there is a set screw on the bottom that you can use to raise/lower the antenna for lowest swr.
if you're using a 102" whip, you just have to trim the antenna in small (very small) amounts. remember, you can always snip another 1/8", but you can't put it back.
Old Sep 11, 2007 | 02:10 PM
4Crawler's Avatar
You can get tan SWR meter from Radio Shack, I think mine ran $10 on sale, or some radios have a built-in SWR meter. Easy enough to do:
http://firestik.com/Tech_Docs.htm
If you want to find a shop, might have better luck along the major interstates, find a truck stop and see if they can reccommend a local CB shop.
Old Sep 11, 2007 | 05:42 PM
Expat's Avatar
If you can get to Agoura Hills you can use my SWR meter. Pretty darn easy.
Cheers
Mark
Old Sep 12, 2007 | 12:24 AM
olharleyman's Avatar
You can go to Castaic about 5-10 miles from 5/405 junction there is a radio shop in front of the truck wash by the Giant truck stop that can tune the radio and get you some dead key and swing then tune your antenna.
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
zombie_barbarossa
Oct 2, 2015 10:54 PM
the_supernerd
Oct 1, 2015 09:20 PM
tazman1972
11
Sep 28, 2015 10:32 PM
