GPS & Communication Discussions here pertain to the use and troubleshooting of GPS, CB radio, and amateur radio
cb radio?
Old Sep 23, 2007 | 05:34 PM
killa b's Avatar
cb radio?
ok me and a buddy got our cbs installed and we cant seem to comunicate with them is there anything were missing or not doing correctly thanks
Old Sep 23, 2007 | 06:43 PM
cubcilecaptive's Avatar
Are they turned on? Tuned to same channel? just kidding...
Check your grounds. What type and model of antenna are you each running (mag mount/Firestick/steel whip)? Did you "tune" them with a meter? Can you hear anything on your radio (another person rather than your buddy)? What model CB?
Old Sep 24, 2007 | 04:12 PM
killa b's Avatar
i have a steel whip atena and im not sure what he has. i have a cobra not sure what model and they are not tuned. shouldnt we atleast hear something and i have not been able to hear any body on mine at all. any help would be appricated thanks
Old Sep 24, 2007 | 04:36 PM
Gator's Avatar
you may have already burned up the finals trying to use it. Find someone close by that knows how to tune an antennae. They will be able to tell you for sure.
Old Sep 24, 2007 | 04:41 PM
killa b's Avatar
what are those finals that i might have burent up. are there any shops that might be able to tune it. im preaty clueless about all of this but thanks for the help
Old Sep 24, 2007 | 04:51 PM
KevinInSac's Avatar
Try to find a local truck stop. They should know of a good local place or two.
Try the weather channels, if you can get them. That way you can determine if you can recieve at all.
Make sure your squelch isn't maxed out, it'll block everything out...
Also, make sure your RF gain isn't turned down all the way, you won't be able to pick anything up.
Old Sep 24, 2007 | 05:00 PM
Gator's Avatar
Here is some basic info on what SWR is:
http://www.firestik.com/Tech_Docs/swr-intro.htm
They mention the use of dual antennas, but don't even think about it unless you are driving Tractor trailer rigs with at least 8' between antennas. There's entire forums dedicated to that whole argument.
Old Sep 25, 2007 | 03:34 PM
killa b's Avatar
ok lookin at my cb and i have a swr cal knob does this do me any good.
Old Sep 25, 2007 | 03:40 PM
KevinInSac's Avatar
That's the easiest way. So follow the instructions on firestik, and watch that meter.
Old Sep 25, 2007 | 07:07 PM
killa b's Avatar
ok got it workin i figured out i can calbrate the cb with the swr knob it even has a gauge on the cb thanks for all of the help.
kawazx636
Oct 6, 2021 03:03 PM
mct75
Aug 22, 2016 01:24 PM
zombie_barbarossa
Oct 2, 2015 10:54 PM
tazman1972
11
Sep 28, 2015 10:32 PM
ctheiss
Sep 14, 2015 12:18 PM
