GPS & Communication Discussions here pertain to the use and troubleshooting of GPS, CB radio, and amateur radio
CB problem....help please..
Old Feb 12, 2006 | 04:52 PM
6lug's Avatar
I dont know why, but my CB will not stop jumping to channel 9....every time i turn it back the the used channel, it jumps back to 9. Any reason for this?
Old Feb 12, 2006 | 04:57 PM
Tofer's Avatar
Sponsor
what type of CB is it? does it have power all the time or only when the trucks on? mine will auto jump to 9 when it loses power.
Old Feb 12, 2006 | 05:00 PM
6lug's Avatar
it has power only when the truck is on...its wired into one of the fuses. its a cobra from walmart...I forget which model...
Right now it doesnt have an antenna on it, but my wheelin buddies were close enough that I would pick up....do you think that it might be losing there signal and then jumping or no...
Old Feb 12, 2006 | 05:07 PM
Bob_98SR5's Avatar
channel 9 is the universal emergency channel. i betcha you have something set where it defaults to ch 9.
read your manual
bob
Old Feb 12, 2006 | 05:09 PM
Tofer's Avatar
Sponsor
dont broadcast with no antenna on it.. it will burn out the crystal i've been told..
Old Feb 12, 2006 | 05:56 PM
Ric's Avatar
Ric
Banned - User requested
if you have 2 hot wires, one is red, one is orange.. one is for a constent hot, the other is for memory..
dont quote me on this part. the ORANGE is constent hot (for the memory), the RED is the power, to turn off with the key.
hope this helps.
Old Feb 12, 2006 | 07:06 PM
6lug's Avatar
Bob, thats what I was thinking, but I didnt know for sure if there was a default...you are right, I just need to read the manual...
Chris, I didnt know that...thanks.
Ric...I believe your right...thats how mine is set up...it turns on when the car is on ONLY.
Thanks guys,
Alex
Old Feb 12, 2006 | 07:12 PM
Bob_98SR5's Avatar
Thanks guys,
Alex
now is this a cb you just installed? Has it worked before w/o this same problem?
my cb has a channel lock. perhaps that is what's preventing you from using other channels
bob
Old Feb 12, 2006 | 07:27 PM
6lug's Avatar
no...Ive had it for a little while, and yes it has worked without this problem before. It will change channels, but only for 5-10 seconds, and I can talk on them, but when I let off the mic, it goes to 9. I know thats the emergency channel, but Im wondering if its, like you said, on some default mode or if its messed up....i dont have a clue why it would keep jumping like that.
Old Feb 12, 2006 | 07:31 PM
Bob_98SR5's Avatar
yeah, it does sound like a program/setting issue.
Old Feb 12, 2006 | 07:35 PM
6lug's Avatar
Well, thanks for your help anyway man.
Alex
Old Feb 12, 2006 | 07:41 PM
Jeffires's Avatar
The wiring advice already posted is probably more of an issue, but I know some radios have a switch to go directly to Channel 9 for emergency. See if it has such a switch, I had a Cobra that had it. And as ToeferUOP said, definitely dont key up with no antenna. Good luck. And if you can't fix it, take it back to Wal Mart because they guarantee customer satisfaction.
Old Feb 21, 2006 | 07:22 PM
geordie's Avatar
Actually it unloads the transmit section and burns out the power transistor in the output stage, but modern hardware often has protection against this.
DEZERTKAOS
Apr 29, 2015 08:15 AM
86yotawheeler
Jul 16, 2014 08:30 AM
StangBanger
Sep 10, 2009 06:06 PM
leah828
Jun 3, 2009 07:38 PM
