GPS & Communication Discussions here pertain to the use and troubleshooting of GPS, CB radio, and amateur radio
Alot of engine noise in my CB while driving !
Old Feb 14, 2005 | 06:42 PM
Stegall984R's Avatar
From: OmG, Hi2U !!! .... DANG, my chic's got some SEXY eyes.... among other things. WOOT WOOT !!
im gounded to the fire wall on a good solid connecion, and the powe is directly from the battery.. i get all kinds of damn noise when i acclerate sp when im on the interstate. any ideas ?
am i more likely getting noise from the power leads, or from the coax
Old Feb 15, 2005 | 05:12 AM
4Hummer's Avatar
I had the same problem. Added a Noise filter inline with the power wire from the battery. Problem solved
Old Feb 15, 2005 | 06:03 AM
midiwall's Avatar
It's noise generated from the power leads and picked up by the antenna. Like Michael said, hit up Radio Shack and get a "noise suppressor" kit. It sits in the power line and should clear things up.
Old Feb 19, 2005 | 03:22 PM
4Crawler's Avatar
I run an in-line filter on mine as well, but I also ran the power *and* ground wires back from the battery. Wires are twisted together as they run. This helps to minimize any ground loops and keep noise out of both leads. With power from the battery and ground at the firewall, your radio is picking up all the electrical noise from everything in between the two connections. Essentially you have a loop antenna wrapped around the engine.
Outsane
Jul 15, 2015 05:01 AM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
camdenbuck
Jul 7, 2015 07:33 AM
Jnkml
Jul 6, 2015 01:20 PM
puddlepirate
Jun 30, 2015 05:08 PM
