GPS & Communication Discussions here pertain to the use and troubleshooting of GPS, CB radio, and amateur radio
Camary05 GPS function
Old Feb 23, 2005 | 06:03 PM
MellowYellow's Avatar
GPS function disabled when moving
I cannot select a destination when moving. I know that this is a "safety" feature but when I have a passenger I would expect that the the system should be operable by the passenger.
Any thoughts on how to resolve this issue?
Old Feb 24, 2005 | 06:44 AM
UNLIMITED96's Avatar
same problem on our sienna, guess they don't want you having accidents,
kind of a pain in the ass to have to pull over on the freeway.
we have a dvd in the dash and in back , when you release the parking brake
the in dash dvd player goes off , i wish i could bypass it.
probably an easy fix just haven't looked yet.
ERIC
Old Feb 24, 2005 | 03:38 PM
I understand that Toyota wants to avoid the legal liability of someone paying attention to the GPS rather than driving then blaming Toyota rather than take responsibility themselves... but there are many other features/functions that can be operated with the car in motion.
My guess is that if you could figure out how the GPS senses that the car is in motion and then defeat that signal/sensor input to the GPS, you could solve this problem.
Anyone have any ideas?
Old Feb 24, 2005 | 06:26 PM
hutch24's Avatar
If its anything like the aftermarket dvd players there is just a wire hooked either to your parking brake or the transmission. All you have to do is ground that wire and it should work.
Old Mar 2, 2005 | 02:03 PM
aowRS's Avatar
Those Camry NAV take-offs use both a regular GPS antenna/sensor, as well as a hard-wired connection to a speed sensor wire behind the instrument panel. I can't think of any way that one could get around this safety feature. If you were to disconnect the speed sensor wire temporarily, the NAV would probably shut down. Same for the GPS antenna wire.
I am still considering this mod...
Andreas
kawazx636
Oct 6, 2021 03:03 PM
hiluxinargentina
Sep 30, 2015 11:12 PM
puddlepirate
Sep 29, 2015 08:02 PM
charlie_fong
Sep 27, 2015 10:06 PM
Boomer8404
Sep 24, 2015 01:12 PM
