Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
Speaker Replacement. '91 4runner
Old Jul 12, 2003 | 07:31 PM
What are the speaker sizes for the '91 4runner?
Old Jul 12, 2003 | 07:41 PM
Shoorty911's Avatar
Front dashes are size 4T.....NOT 4"......and the rear speakers are 5"....
Shoorty
Old Jul 12, 2003 | 09:13 PM
Vato Loco's Avatar
Just replace the rear speakers with 6x9's
Old Jul 13, 2003 | 04:28 PM
Where do I find GOOD speakers for '91 4runner
4t And 4 inch? Where can I find comprable s[eakers for my '91 4runner
Old Jul 13, 2003 | 05:16 PM
Shoorty911's Avatar
The size for you front speakers are 4T......4T and 4" are technically the same size but mount differently......so make sure you get 4T for the front dash....
Old Jul 13, 2003 | 05:27 PM
Yoter's Avatar
Guest
6x9's in the rear.
They won't fit in the panel will they? If they do then I am going to do 6x9's in my 91. I put Alpines in my dash Shoorty and they are crystal clear.
Old Jul 18, 2003 | 12:56 AM
4t speakers?
Are 4t speakers the only speakers that will fit in the front of my '91 4runner? Regular 4" speakers won't fit? Oh yeah and where can I buy some of these 4t speakers?
Old Jul 18, 2003 | 04:41 AM
Vato Loco's Avatar
Re: 4t speakers?
I put regular 4" inch speakers in the 2nd gen I use to have, it doesn't fit perfectly. You could only use two of the screw mounts since its not a perfect fit, but it will work.
Old Jul 18, 2003 | 09:43 AM
Yoter's Avatar
Guest
Re: Re: 4t speakers?
I agree, the four inch works just aswell as the four T. I have Alpines down there and they are crystal clear.
Old Dec 9, 2005 | 12:06 AM
6x9's will Fit in my 91 4runner?
Old Dec 9, 2005 | 12:51 AM
6x9's In a 1991 4runner? Possible?
Ok so I have a nice deck but blown 15 year old speakers. I think it's about time to upgrade. I have some 4" speakers for the front but I heard that you can put 5.25" speakers up there. Also I want to put some 6x9's in the back. I do a lot of transporting so I don't have anyroom for a sub.
Does anyone know if this iss possible or know of a way to make this happen?
Old Dec 9, 2005 | 01:38 AM
bob200587's Avatar
take the speaker hole apart and see what you're working with. I put my 6x9s in the stock spot meant for 5 1/4s. yours proabably similar to my 87 and I just put them in there and screwed in one screw. I coulda done a better job but I'm lazy and haven't had a problem with them since so I havent done anything to it. As far as the front....aftermarket 4 inch speakers barely fit in mine. I wouldnt even bother anyways....the 4s put out good sound.
Old Dec 9, 2005 | 06:55 AM
Astralplane's Avatar
This is what I installed several years ago, unfortunately R/F discontinued the "T" model. The picture shows the 2 posts for Toyota, instead of the typical 4 posts.
http://www.carreview.com/cat/car-aud...9_1805crx.aspx
http://www.crutchfield.com/S-sQSc1ol...p?I=575FRC220T
Old Dec 10, 2005 | 06:13 PM
Are some 6x9's flatter than others?
Old Dec 10, 2005 | 06:17 PM
bob200587's Avatar
check the specs. there might be. The brand websites proabably have them. check between them.
Old Oct 9, 2007 | 08:46 PM
WCorbett's Avatar
Does any one know the size of the back upper corner speakers?
Old Oct 9, 2007 | 09:52 PM
stormin94's Avatar
Huh??? How many speakers does yours have?
Old Oct 10, 2007 | 08:39 PM
WCorbett's Avatar
6. same as all the other 4runners lol
Old Oct 10, 2007 | 09:47 PM
stormin94's Avatar
Not quite. Mine has four. Where are your speakers mounted?
Old Oct 10, 2007 | 10:30 PM
rocket's Avatar
6 speakers was an option on 2nd gens. The majority have 4...
